When did common rails come out?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Davo81, Apr 10, 2018.
  1. Davo81
    Davo81 Light Load Member
    64
    15
    Aug 5, 2011
    Melbourne, Australia
    When did Detroit, Cat and Cummins introduce common rail injection?
  3. Bean Jr.
    Bean Jr. Road Train Member
    5,467
    9,697
    Mar 30, 2014
    They didn't call it that, but Cummins had a single injector line starting with the NH series in the early 1950s. Detroits had them from the beginning.
    I don't know if the E model used a distributed type pump but I know my b did.
    I started hearing the term "fuel rail" after Cummins introduced the ISX.
    Davo81 Thanks this.
  4. Davo81
    64
    15
    Aug 5, 2011
    Ahh yes, I have heard of that! So, basically, the Series 60, Cummins Signature and the 3406e/C15 are all electronic common rails per-say?
  5. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Yes and no......
    A common rail injection system on today's modern diesels operates at very high pressure, like 35-40,000 psi. And has a high pressure fuel pump to make those pressures.
    A series 60 , n14 ,c15 and E model 3406 are not like that. The only thing they have that's sort of similar is the fast that the injectors are all fed by a common fuel galley in the head . Technically these are not considered a " modern common rail engine".
    Nor is a 3406b for that matter.
    True modern common rail injected diesels are the dd15/16, ISX/x15, PACAR, basically any engine in a new truck now a days.
    These common rail engines first came out with the introduction of the ISX. Possibly Volvo then too. Then shortly after the DD15
    Bean Jr. Thanks this.
  6. Hulld
    Hulld Road Train Member
    2,882
    6,564
    Oct 19, 2015
    Upstate NY
    The first year of a Cummins common rail b series engine is 2003 I believe.
    But that’s a much smaller medium duty engine.
    spsauerland Thanks this.
  7. pushbroom
    pushbroom Road Train Member
    1,777
    7,253
    Sep 1, 2012
    Isx went common rail late 2010 with the introduction of the ISX2250.
  8. Davo81
    64
    15
    Aug 5, 2011
    So, the modern, true common rails should be more economical?
  9. spsauerland
    spsauerland Road Train Member
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    Yes and no. Common rail in the lastest engines have the capability for nine injections in a single injection event. This leads to a more efficient burn and higher thermal efficiency of engine. That being said, most all HD engines in US that us common rail injection also use EGR and DPF that lower efficiency. Also, while they are getting better, newer engines have more maintenance issues, breakdowns, and downtine. Better economics... I would say a pre-egr engine or properly "tuned" emissions engine would win. Just my opinion from what I have seen.
    pushbroom Thanks this.
  10. Davo81
    64
    15
    Aug 5, 2011
    It sounds like there might be a market for converting older engines to a true common rail system?
  11. pushbroom
    1,777
    7,253
    Sep 1, 2012
    Not worth it. Easier to modify current common rail engines to older emission standards.
    Roberts450 and spsauerland Thank this.
