When are we required to log a petrip inspection?
Discussion in 'Questions From New Drivers' started by A Bug, Jul 20, 2018.
  1. A Bug
    A Bug Heavy Load Member
    827
    1,575
    Mar 15, 2014
    Sevierville TN
    I am splitting my ten hour break tonight. I am just about done with my 8 hours in the sleeper berth.
    I assume a pretrip inspection is required at that point, but is it?
    Will logging an inspection be required after my 2 hour break that I will be taking in a few hours from now instead?
    Or maybe even both.
    Lepton1 Thanks this.
  3. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,541
    May 22, 2017
    Beginning of day or end of day. And anytime 10 or more is off duty or sleeper.
    I used to do at start of day as I fueled, than the next morning again.
    So after your done driving your left over hours take a post trip.
  4. Bean Jr.
    Bean Jr. Road Train Member
    5,467
    9,697
    Mar 30, 2014
    Different companies have different policies, so I am guessing the FMCSA is satisfied with all of them. My carrier wants us to flag a pre-trip and log a post trip.
    Something that people should be aware, it is not a requirement to describe which activity caused your change of duty status. You were in the sleeper, then spent 15 minutes performing a PTI, then start driving. According to the guidance from the FMCSA, you do not have to write "pre-trip" or "PTI". That is a carrier requirement.
    stwik and not4hire Thank this.
  5. Rubber duck kw
    6,092
    17,685
    Dec 9, 2017
    Is logging a pretrip even required? I only ask because I just go right to driveline from off duty or sleeper and nobodys ever asked about pretrips or said they had to be on duty.
    Bean Jr. Thanks this.
  6. Snoopycda
    Snoopycda Medium Load Member
    361
    714
    Jan 22, 2016
    Edmonton Ab.
    You have to show an inspection of equipment when you get pulled over. Pre-trips are not instant unless you are pencil whipping them, logged as on duty not driving.
    Someone correct me if I am wrong but you must show an inspection of equipment every 24 hours minimum.
  7. Rubber duck kw
    6,092
    17,685
    Dec 9, 2017
    I guess I end up with enough time waiting in lines on duty not driving they probably just assume it's in one of those.
  8. Snoopycda
    361
    714
    Jan 22, 2016
    Edmonton Ab.
    Never let DOT assume things. They will always be negative assumptions.
    stwik and singlescrewshaker Thank this.
  9. not4hire
    not4hire Road Train Member
    7,142
    26,957
    May 16, 2012
    Calgary
    That's a Canadian requirement.
    (4) Required inspections (when operated)
    (a) Trucks, tractors and trailers shall be inspected in accordance with Schedule 1 every 24 hours.​
    - http://www.ccmta.ca/images/publications/pdf/nsc_standard_13_update.pdf
  10. Rubber duck kw
    6,092
    17,685
    Dec 9, 2017
    I've never had them even ask me about it, not when they did my new authority audit, not in a scalehouse, not on the side of the road.
  11. dibstr
    dibstr Road Train Member
    1,308
    931
    Sep 10, 2010
    Nope, as Bean said above there is no fed requirement to note an inspection on a log. For that matter there is no requirement to ever show anything you did on a log.
    Question 23: When the driver’s duty status changes, do §§395.8(c) or 395.8(h)(5) require a description of on-duty not driving activities (“fueling,” “pre-trip,” “loading,” “unloading,”, etc.) in the remarks section in addition to the name of the nearest city, town or village followed by the State abbreviation?
    Guidance: No. Many motor carriers require drivers to identify work performed during a change of duty status. Part 395 neither requires nor prohibits this practice
