Wheeled landing gear
Discussion in 'Ask An Owner Operator' started by SemperFiServices, Feb 15, 2019.
  1. SemperFiServices
    SemperFiServices Medium Load Member
    379
    230
    Jan 29, 2013
    Indianapolis, IN
    Haven't been driving long enough to know the answer ( did my 20 in the Marines before becoming an O/O), but I was curious about the steel dolly wheels you see on some old trailers. Why were they used instead of the flat feet we have now? Was it to be able to push the trailer around? Aside from them being easy to sink into asphalt and dirt, why and when did they stop using them?
  3. ZVar
    ZVar Road Train Member
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    This is likely a question for our resident trucking history buff. @Mike2633 hopefully can tell us.
    Mike2633, SemperFiServices and bzinger Thank this.
  4. p608
    p608 Road Train Member
    2,181
    2,991
    Nov 10, 2016
    Back in the day trailers had no maxi brakes,when the air leaked off the brakes released, when a truck tried to hook the wheels would let it roll instead of bending the landing gear.
    Grubby, SL3406, whoopNride and 5 others Thank this.
  5. SemperFiServices
    379
    230
    Jan 29, 2013
    Indianapolis, IN
    Thank you!!
    Mike2633 Thanks this.
  6. Buckeye 60
    Buckeye 60 Road Train Member
    1,229
    1,268
    Apr 19, 2018
    thank you and I have been driving since 85 and I didn't know why either lol
  7. Rideandrepair
    17,201
    55,791
    Aug 8, 2015
    I always wondered myself. Next question is how many got dropped on an incline and just rolled away!!!
  8. adayrider
    adayrider Road Train Member
    1,289
    1,732
    May 7, 2018
    Back then they were smart enough to block the wheels and back up to it and hook airlines up before backing under.
    AModelCat and Rideandrepair Thank this.
  9. Rideandrepair
    17,201
    55,791
    Aug 8, 2015
    I worked at a local job in 95 that had some old quads with two front axles welded up in place no drums, brake shoes or wheels, dollies had wheels.We’d drag them aroun the city, their “official “ policy for hooking all trailers was to hook up , charge and apply brakes. They were probably 1970s trailers. Only good thing about Driving junky equipment is you learn all kind of tricks.Like dipping pigtail in tank, bungee cord gearshift in top gear, never trusting a fuel gauge. And my favorite, running a small wire from fuse panel to pigtail for Trailer running lights. Lol, I don’t miss that job at all.
    Grubby and adayrider Thank this.
  10. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    Or back close to trailer and hook air lines, charge air tank, if need be, then you can lock brakes on to back under it. ( opps you did say that) lol on the "smart enough". I sense sarcasm. On the wheel landing gear...some container chassis still use them. Have no idea in the reason of wheels. Unless the yard truck, or someone don't lift landing gear up far enough they would have more of a roll instead of gouging effect? Not suprised though, (still on chassis)spoke wheels, tube type tires, and some tubeless. The tire casings are almost always 10 years old unless its a new(er) chassis.
    Grubby Thanks this.
  11. 1johnb
    1johnb Medium Load Member
    542
    405
    Jun 13, 2012
    New Paris Ohio
    My father in law worked at Dayton tire in Dayton Ohio. When the trailers would loose air of course they wouldn't have parking brakes. The forklift drivers would go into the trailer real fast and slam on the brakes. This would cause the trailer to roll away from the dock. Needless to say they were on break until someone could put the trailer back to the dock.
