Wheel seal question
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by EWV, Aug 14, 2019.
  1. EWV
    EWV Light Load Member
    80
    27
    Mar 22, 2016
    Hi is it common practice to use silicone when fitting new wheel seals?
    Had a safety end of april and a wheel seal went yesterday...had it put right but the mechanic said hed never ever seen anyone put silicon a wheel seal before.
    Wondering if its something should never be done or just a preference thing?
    Thanks
  3. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    Depends on the seal brand and the location of the silicone. Stemco 2 piece requires RTV on the wear sleeve to the axle. I would say if it was used any other way it wasnt correct.
    Rideandrepair and EWV Thank this.
  4. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    It's an extra layer of protection. Some guys do it, some don't. I like to use #2 on the outside of a CR or old school Stemco seal.
  5. EWV
    80
    27
    Mar 22, 2016
    Ok thanks
  6. EWV
    80
    27
    Mar 22, 2016
    Thanks appreciate the info
    Goodysnap Thanks this.
  7. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    I have used silicone on hundreds of them, stemco, national , it doesn't matter, if used where it is intended to go
  8. Goodysnap
    3,694
    8,948
    Jul 12, 2017
    Ok......I'll play.
    What wheel seal manufacturer's instructions call for RTV on seal installation? Are we talking seal to hub surface? If I have to glue it in I'd rather not use the seal at all.
    If additional sealant is required to keep the seal from leaking either theres something wrong with the hub or other? If a seal has issues leaking as installed maybe one should be spending more money on a higher quality seal that doesnt need additional sealant to keep it from leaking.
  9. starmac
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    I do not know of any manufacturer that calls for it. On stemco I use it under the wear ring if there is a bad spot on the surface, which is the only time I will use a stemco anyway, and may or may not put some between it and the hub, I am talking a very fine film. On national I will use some (fine film) between the seal and the hub. I have seen guys use it on the spindle surface with national when it has a bad spot with success, but I just use a stemco in those cases.
    Rideandrepair Thanks this.
  10. Working2party
    Working2party Medium Load Member
    608
    729
    Feb 10, 2018
    Kansas
    Yes, a thousand times yes. Completely agree!!!
    I’ve used the national 3800 series seals for 13years. The only time they didn’t hold for the reasonable/ expected amount of time was when there was a problem with a plugged vent or the bearings. (Mis-adjusted, or pitted conditions)
    Yes silicone probably may have kept the seals from leaking..... up till my mistakes came out and the bearings failed!!!
    It’s like supergluing all the doors shut in your house just to make sure your wife hears all the points of your argument, just to realize half way through that ....
    You where were in the wrong!!!
  11. EWV
    80
    27
    Mar 22, 2016
    Ok thanks..the answers from Goodysnap and Working2party are exactly the concerns i had and why i asked the question un rwgards to the remaining wheels.
    I will just have to be vigilant
    Thanks again
    Rideandrepair and Goodysnap Thank this.
