Wheel Polishing Jig
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Caterpillar Cowboy, Apr 1, 2011.
  1. Caterpillar Cowboy
    Caterpillar Cowboy Heavy Load Member
    837
    607
    Nov 11, 2010
    Wyoming
    Common scinareo, Hate to polish, but Love the polished look. I got to thinking about making a jig/machine to do this, I see some places sell them, but I bet they are expensive as all hell. I got to thinking about getting a old engine and 2wd trans out of a old pickup, and building a frame for it and have the driveshaft run to a hub where you could bolt a 10 lug aluminum wheel to it, turn it on and get to polishing. Granted it'll be a little dangerous, but a whole lot safer than jacking up all 4 sides and firing up the truck and letting it idle in gear. Anybody got any thoughts on this, or someone who'se done it got a drawing or pictures I could go off of?
  3. Caterpillar Cowboy
    837
    607
    Nov 11, 2010
    Wyoming
    Or just to buy a whole 4wd pickup or blazer say, pull off the body sheetmetal, and make a adapter from the truck's lug pattern to the 10 lug pattern, just jack it up and mount all 4 outter drive rims to it and run her in 4wd and get 3 buddys to help!
  4. REDD
    REDD The Legend
    6,237
    4,291
    Jun 29, 2009
    Dueling Banjoville
    Go to Walmart & spend $30 on a buffer machine....
    You'll have your high speed polisher then
    canuck in da truck Thanks this.
  5. Caterpillar Cowboy
    837
    607
    Nov 11, 2010
    Wyoming
    Use a power ball on a drill now, does the job but just takes forever.
  6. underpsi
    underpsi Road Train Member
    1,266
    292
    Sep 18, 2008
    Toronto, Ont
    Think you got the right concept but wrong idea. Having a actual engine just to turn the rim is a huge over kill. You could just simply make a hub for an electric motor and put a variable speed switch on it.
    Even then you'll still want a buffer to use while the rim is spinning.
  7. canuck in da truck
    canuck in da truck Road Train Member
    4,352
    2,601
    Aug 6, 2010
    western pa
    i think you have been watching junkyard wars too much--sounds more like helicopter you are trying to build
    you really dont need anything to high speed--just take a look and a few pics at the commercial polishers set up--and away you go
  8. AUSSIE DAVE
    AUSSIE DAVE Road Train Member
    1,032
    176
    Feb 21, 2010
    OZ - Brisbane
    i saw a guy on utube jake up his car put it in gear so back wheels turn, then he just sat there with a cloth and polish compond
  9. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,652
    15,971
    Jan 18, 2011
    As much as I enjoy creative engineering--and could see myself and a couple of my other motorhead buddies doing this for S***S&Giggles--I have to say--there are just too many places around the country where you can get polished for a very reasonable price--I know you have to sift thru all the BS--crackheads etc. that claim to be polishers--but it can be done--so on a cost basis I just couldn't justify it--now if you would take that same perfectly good almost running 4wheel drive pick up--dump 100man hours and 10k into the motor--mount a vega body on top of it--find a way to mate a perfectly good double reduction gearbox out of a wrecked Pete to it--just to pull a homemade sled 100ft at the local fairground Sat. nite--so you can drink beer with your buddies--just so you can say--it's not like we were just sitting around at the bar BSing--Now that is a perfectly reasonable expenditure! LMAO
    Strider Thanks this.
  10. Caterpillar Cowboy
    837
    607
    Nov 11, 2010
    Wyoming
    That's the concept I was going off of. Praticularly this one...
    http://www.youtube.com/watch?v=rl5c7Ih2GW4
    I'd however want to polish the rims with tires still mounted. Trusting a 150K new dump truck to four 20 ton hydraulic jacks I just do not think is a good idea. I could have visions of a jack leaking down and not noticing it and before I know it my shop door is gone, and my truck is trying to have an affair with a tree acrossed our parking lot.
  11. SL3406
    SL3406 Medium Load Member
    550
    1,482
    Jan 10, 2011
    Oklahoma
