Wheel lathe for polishing
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mitmaks, Mar 19, 2018.
I get mine machine polished to look better than new 75 a wheel on a machine
SAR Thanks this. -
Well I can do my own wheels, just need to get some kind of wheel stand to mount rim onto
I would start with a cement mixer to turn the wheel. The older and heavier the better.
Just jack the wheel end up that you'll polish and stick er in 3th or so. Or get it up into high range if you're brave. Very important that you DON'T LOCK your power divider or diff locks. Also if you have a jack that bleeds down I highly recommend jack stands.
Ruthless, lester, DieselDrivinDaddy and 1 other person Thank this. -
Leave the wheel mounted and jack up that position then start polishing. The drag from the buffer will turn the wheel. You'll have to use your foot to slow the wheel down occasionally. That's how I do it. Engine off.
The problem is that I need to polish around lug nuts as well.
Oxbow Thanks this.
