Wheel bearing grease
Discussion in 'Ask An Owner Operator' started by Dan_chicago, Aug 9, 2021.
  1. Dan_chicago
    Dan_chicago Bobtail Member
    10
    4
    Aug 31, 2015
    Hi,
    The wheel bearing in my dad's trailer aren't lubricated by oil, they're greased.
    Does anyone know how what is the proper procedure for replacing the grease? We don't want to just shoot in new grease because we are afraid that putting in too much will actually damage them and make them overheat.
    Thanks
    Dan
  3. xsetra
    xsetra Road Train Member
    5,094
    6,941
    Aug 21, 2011
    Preventive maintenance.
    When I changed my grease in trailer hubs. I would remove the entire hub and clean all the old grease out. You need a new inner seal and do a good wash and check the old bearings. I would replace the bearings on my trailer every couple three years, bearings are cheap. This was me doing the labor, my shop rate is cheap to me.
    I don't think putting to much grease will overheat the bearings, but it could blow out the inner hub seal. I don't know the amount of grease to put in your axle end. Look that up on the axle manufacture website. You can find recommended procedure for maintenance there also.
    You will need the socket for the axle nut if you remove the hub.
    Search for information on this website by using the search on the top right side of this page.
    Good luck.
  4. jason6541
    jason6541 Road Train Member
    2,425
    5,365
    Mar 5, 2012
    Omaha, NE
    I assume your talking a commercial semi trailer?. Not a utility type trailer?.
    I use Kendall semi fluid grease in my Great Dane trailer. Don’t even think of using regular old HP grease in those hubs but best way pull them down inspect and like mentioned before replace seal and outer hub gasket and keep trucking.
  5. Rideandrepair
    17,209
    55,822
    Aug 8, 2015
    D12960D6-AAED-4A53-B200-9DC3C0C03E60.png Mine has grease. The Trailer shop says they use regular grease. Other Shops tell me the same. I don’t think regular grease is good enough for longevity. My research showed a special grease. I think it’s 00 weight. I took mine off. Grease was still intact. Bought my Trailer from Penske. Asked them what kind of grease it was. They said they put it in all they’re Trailers when new. No more wheel seals to repair. I’m a believer after seeing mine intact so well after a lot of years and miles. Can’t believe such a light weight grease,( almost an oil) stays in place so well. The procedure is to clean and pack the bearings properly, same as any wheel bearing. Grease up spindle and races. Torque. Packing all voids, in the hub/ bearing. Then add extra in the grease (hub) cap. Basically holding it at an angle, filling it from the center to the lip. Then install hub cap About 1/3 ways full. You can find instructions online with pictures and examples. Here’s the oil. Shell and others make comparable oils. Same 00 weight. Hard to find and expensive. 5 gal jugs online. Look enough, you can find quarts of it. I plan on repacking my Trailer bearings, and also do the steers on my Truck with this grease. Do your own research. Make your own decisions.
  6. Rideandrepair
    17,209
    55,822
    Aug 8, 2015
    Just a note. There’s been some debate about grease wheel ends failing and hubs/wheels coming off. Apparently there was a problem with old style Trailer hubs and bearings. The outer bearing was smaller than the inner bearing. That caused the outer bearing to run dry, and get rusted and fail. Newer upgraded Hubs and bearings are the same size. I had a failure on my last Trailer. Although it had oil. The new hub Kit I bought had the larger outer bearing. Didn’t think much about it at the time. But it makes sense now. Make sure you have the same size inner and outer bearings, before switching to grease.
    black_dog106 and Stray_Dog Thank this.
  7. Dalton07
    Dalton07 Bobtail Member
    21
    Jan 18, 2022
    The wheel bearing grease is invaluable in greasing up bearings and ball ends. I use the Valvoline synthetic grease on literally everything I have that needs lube. I use this stuff because it's effective. Just cut the tube down as you use it and you won't have any issues getting to all of it.
    Rideandrepair Thanks this.
  8. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
  9. Dalton07
    21
    Jan 18, 2022
    There are also many other types of wheel-bearing grease that you can try as Lithium grease which is best used for metals that are subject to high temperatures and pressure. if your camper is frequently exposed to wet environments, such as swampy areas, should try the marine wheel bearing grease,
  10. MTMAUS
    MTMAUS Light Load Member
    222
    175
    Sep 28, 2019
    How often would you change the grease on trailer hubs?
  11. jason6541
    2,425
    5,365
    Mar 5, 2012
    Omaha, NE
    I always did it at every brake change. Pull hubs down clean and inspect
