What's with the plastic???
Discussion in 'Experienced Truckers' Advice' started by snowlauncher, Nov 18, 2014.
  1. snowlauncher
    snowlauncher Road Train Member
    1,230
    2,599
    Mar 28, 2014
    Southeastern ID
    I see a lot of trailers with plastic hanging out of the door seals. Mostly seems like roll-up doors. If I guessed I would say the doors don't seal and the plastic seals it from the elements, but I wanted to know for sure. Is it a jury-rigged door seal and if so why do I see so
    many like this? Why not just fix it?
    Chinatown Thanks this.
  3. Chinatown
    Chinatown Road Train Member
    73,250
    164,502
    Aug 28, 2011
    Henderson, NV & Orient
    In my experience with roll-up door reefer loads, many times each pallet is covered with a big plastic bag, usually much bigger that the pallet. The last two pallets sometimes the excess plastic sticks out from under the door. Hard to push it inside due to air pressure from the reefer unit running.
  4. Glp
    Glp Medium Load Member
    348
    285
    Dec 23, 2012
    Oakland, CA
    It is to keep the contents dry from moisture. The roll up door tends to let some water in when it rains
  5. 315wheelbase
    315wheelbase Heavy Load Member
    783
    601
    Oct 26, 2014
    called a rain shield, usually draped over the 2 rear pallets,,roll up doors are not water proof don't worry it plastic upsets tree huggers and environmental wackos
  6. CMFofNC
    CMFofNC Bobtail Member
    38
    14
    Nov 12, 2014
    Roxboro, NC.
    I worked 31 yrs.'. for B&W Tobacco Corp, (Lou, Ky. & Macon, Ga.)our shipping department gave up on getting dry vans so started using Hugh plastic bags to seal the load. They would run fans at the back of the trailer to inflate the bag, it would completely fill the trailer. They could then drive in the forklifts with the palletized cases. Sometimes you would have plastic showing at the doors.
    CMFofNC
  7. bigkev1115
    bigkev1115 Road Train Member
    2,363
    3,609
    Oct 23, 2009
    Alexandria, AL
    Plastic is a whole lot cheaper than a damaged cargo claim. That s why you see a lot of FedEx and UPS with plastic hanging out of back.
  8. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,567
    Jul 15, 2006
    El Chuco, Tejas
    For a week I worked loading trailers at Johnson Controls in El Paso. It was the fabric seat covers for cars. They were all floor loaded. We would set up a plastic liner in the trailer, vacuum the air from between the trailer wall and the liner, and load the seat covers. When done we shut off the vacuum pumps and let the plastic liner cover the cargo. Often a bit hung out of the end of a trailer.
  9. Passin Thru
    Passin Thru Road Train Member
    1,918
    565
    Mar 8, 2007
    VA
    Wow! Learned something new. Never saw one on a flatbed load.
    tucker Thanks this.
  10. Allow Me.
    10,642
    12,099
    May 28, 2009
    Rancho Mirage, Ca.
    We used to lay it on the floor and load the freight on top. In the "old days" the floors were wood planks and leaked or possibly leaked from underneath as in driving in rainy weather. You can lay a sheet down in 20 seconds VS sweeping out the trailer which takes 10-15 min. Multiply this by 100 trailers, do you think you're saving some time in a 10 hr shift ?
  11. rockee
    rockee Road Train Member
    1,393
    673
    Apr 17, 2007
    Pacific Northwest
    A lot of plastic you see hanging off the rear covering the lights is just a moisture barrier and if you see it covering the lights it means the driver is too lazy to cut it off.
