What's the point of a grill cover?
Discussion in 'Questions From New Drivers' started by Drivingotr4life, Apr 8, 2018.
  1. Drivingotr4life
    Drivingotr4life Light Load Member
    271
    103
    Mar 20, 2018
    I see trucks with cardboard over their grills and am wondering what's the point? Is it to keep the engine from freezing in the winter or something?
  3. WiggleWagon
    WiggleWagon Light Load Member
    232
    312
    Aug 17, 2016
    Parked At The Fuel Island
    The engine performs best within a certain temp range. Better fuel mileage, etc. When it is cold, this helps keep the engine temp higher.
  4. Streetroddreams
    Streetroddreams Medium Load Member
    424
    568
    Oct 19, 2017
    North Central Missouri
    Higher radiator temp means heater works a lil better also.
  5. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    Too many put them on when they're not really needed (especially with the newer trucks) and don't take them off when they should. Driving new trucks, I won't mess with them. If it gets that cold, I probably missed my turn and ended up way too far north.
  6. pmdriver
    pmdriver Road Train Member
    2,338
    3,503
    Nov 14, 2017
    older trucks needed them sometimes when running in frigid temps so driver would not freeze and them huge teeth would scare many so they move out of the way.
    Bob Dobalina and Trucker61016 Thank this.
  7. blairandgretchen
    13,212
    70,209
    Dec 9, 2011
    South west Missouri
    Helps make your Weber last longer, and look good in the spring when barbecue season begins.
    Oh! Winter front, sorry - just read the title.
  8. 2Girls_1Truck
    2Girls_1Truck Medium Load Member
    513
    640
    May 18, 2014
    Nova Scotia, Canada
    My truck is 2018, only 40,000mi on her now. She will not blow even remotely warm air at idle in a Canadian winter without a winter front. After idling 6 hours, I woke up frozen and the water temp gauge wasn’t registering any temp.
    Even driving in blowing wind and snow, below 0°F my water temp is dropping, and with it, the inside temperature of the cab (and fuel mileage, and probably lots of other crap).
    Edit: I should add that this doesn’t mean I jam cardboard behind the grill, or use bungees to secure garbage from the truck stop parking lot to the hood. I bought a quilted leather, paint colour matched winter front with zippers to adjust the opening and 3m backed snaps for my last truck for $150 at the Peterbilt dealer. Seemed downright reasonable considering how shabby the trash-mobiles look.
    Oxbow, Grubby, AModelCat and 3 others Thank this.
  9. STexan
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    Yes. That's another thing. If you have to warm during breaks with idling, then they're much more necessary during severe cold than if you don't need to worry about long term idling temps and have an APU or Webasto bunk heater
    We have APUs and trucks won't idle yet some guys run the winter fronts all winter long. Severe cold or mild winter temps.
    :banghead:
    2Girls_1Truck Thanks this.
  10. 25(2)+2
    18,749
    45,384
    Sep 18, 2006
    the road less travelled
    They have their place, but I agree, they should be removed and stowed when it warms up. They have openings in the FL ones, no zippers so the openings can't be reduced.
    We had snaps on the grill for the factory covers, but a deer hit got the grill replaced on the one I drive, so I can no longer use one.
  11. tinytim
    tinytim Road Train Member
    5,143
    18,067
    Oct 29, 2007
    Northern Ontario
    Really? Cummins or Paccar? At 30 below my DD15 stays at a good temp and the cab stays toasty warm. I don't have a winter front.
    uncleal13 Thanks this.
