I have a project moving my air lines underneath trailer and was wondering on the minimum height tractor to trailer air lines need to be to keep the law off my keester.
I didn't even think about it until I saw where those dangling lines for sliding tandems need to be a minimum 18" above the ground.
I would assume 18" would apply in my case then when the lines are coming off the rear of the tractor and under the trailer unless someone knows different.
What's the minimum legal height above ground for tractor to trailer air lines?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Semi Crazy, Feb 10, 2012.
No legal limit. really, but generally trailer floor is 1.3m height.
4.10 m, 13.5' in the USA and EU, 16' (5m) in UK.
Really truck makers buid 4.0 m trailers, 10 cm is the bonus to avoid ticketing on every stationLast edited: Feb 10, 2012
Make sure the air lines aint touching either. Believe it or not I got dinged for that a while back. I didnt have "enough" of those little plastic dividers on my trailer airlines and I got a friggin ticket. It was on the trailer air lines that are suspended by the springs. Apparently you cant have the two airlines touching anywhere as they can rub holes in each other.
Picture is worth a thousand words right.
http://www.google.com/imgres?um=1&hl=en&sa=N&biw=1024&bih=653&tbm=isch&tbnid=_GhTOtrydlUC9M:&imgrefurl=http://www.amazon.com/Tramec-34020-Brake-Spacer-Hanger/dp/B001Q6NSX8&docid=3nFGgcUNEj9OwM&imgurl=http://ecx.images-amazon.com/images/I/21mOGYsxutL._SL500_AA300_.jpg&w=300&h=300&ei=oUA1T_vjAoWq2gW0oviNAg&zoom=1&iact=hc&vpx=101&vpy=143&dur=423&hovh=136&hovw=131&tx=126&ty=118&sig=111315946365279363795&page=1&tbnh=136&tbnw=131&start=0&ndsp=18&ved=1t:429,r:0,s:0
Thats the part I was trying so unsuccessfully to describe lol. -
Planning to make a low rider?
I know you'll get slapped if your air lines touch the catwalk, but never heard about them touching each other.skellr Thanks this. -
now Ive got spacers about every six inches, it looks stupid I got so many spacers on there
Gears Thanks this. -
Air lines can touch each other, he maybe saw some rub marks and that is why he gave you a ticket.
I not sure of height, but everybody that I know of ran them out rear frame x- member and they were up pretty close to 2ft+ off ground. I don't know of anybody being measured or hassled. Just don't forget a shut off valve setup so you can keep glad hands on front in case somebody else needs to hook up to it
I've always been told it's 18" on the tandems, but I've never heard or seen a minimum for the catwalk...
jt road hammer Thanks this.
