What's the max weight of loads for dry van?
Discussion in 'Experienced Truckers' Advice' started by OOwannaBE, Jan 28, 2016.
  1. OOwannaBE
    OOwannaBE Medium Load Member
    575
    372
    Mar 12, 2015
    Nashville, TN
    With a standard sized semi with a sleeper? My reefer trailer max load weight is around 45,000 pounds. What is the max weight for a dry van?
    pigeon river trucking Thanks this.
  3. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,567
    Jul 15, 2006
    El Chuco, Tejas
    A lot will depend on how heavy your tractor is.
    The heaviest I've ever put in a dry van was roughly 46,660 lbs. My cat scale ticket said 79,998. Tractor was a Freightliner Columbia.
    Recently I dragged a load home from Washington that had me at 80,360 with full tanks. My Volvo 780 with full tanks and a dry van with full aero doo dads weighs about 33,800. So that load was about 46,560, (44,090 claimed on the BOL!)
    americanmadetrucker Thanks this.
  4. OOwannaBE
    575
    372
    Mar 12, 2015
    Nashville, TN
    Yeah the 780 is huge how about a normal sized truck?
  5. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,333
    Feb 21, 2015
    Bement, IL
    Too many factors to really answer your question.
    Truck model. Truck specs. Engine type. Tire type/size. Wheel type/size. Fuel tank type/size. How much personal effects one carries. Etc. Etc. It all affects the weight of the truck. Two identical appearing trucks sitting side by side can be thousands of pounds different in weight. And then the differences in trailers add to it.
    A good ballpark load weight is probably 42,000 lb. But to really know for sure, top off your tanks and roll onto a scale with an empty trailer.
    (EDIT: But that number comes from my experience with pulling older trucks and trailers. I have no idea how much lighter the newer stuff really is)
    Flipflops Thanks this.
  6. 8thnote
    8thnote Road Train Member
    1,980
    3,686
    Aug 12, 2013
    Chattanooga, TN
    When I drove a fleet-speced Volvo 670, I could load about 47500 with a newer light-weight Wabash trailer. 600-700 less with a older Great Dane trailer. My KW T680 maxed out at about 46000.
    OOwannaBE Thanks this.
  7. 201
    201 Road Train Member
    12,047
    24,590
    Apr 16, 2014
    high plains colorado
    When I hauled RR cans years ago, we were suppose to be able to scale 46K, which was doable in a van ( if the weight was correct) Some containers ( and chassis) weighed as much as a reefer, ( and fixed axles) so lots of going around the scale with those.
  8. Lepton1
    Lepton1 Road Train Member
    12,647
    25,588
    Nov 23, 2012
    Yukon, OK
    There's nothing like picking up a heavily loaded trailer at a company terminal with paperwork that includes a CAT scale ticket showing close to 80K gross, only to find out it was scaled with a day cab.
    str8t10, A21CAV, passingthru69 and 4 others Thank this.
  9. Bean Jr.
    Bean Jr. Road Train Member
    5,468
    9,698
    Mar 30, 2014
    I had a Freightliner FLD daycab that weighed 17,500 with fuel, and a 379 that weighed 18,500 full of everything, including food for the week. You would think a day cab would be more than 1,000 lbs lighter than a sleeper!
  10. PackRatTDI
    14,765
    22,567
    Jul 15, 2006
    El Chuco, Tejas
    I believe it. I think the weight difference between that Freightliner I drove and my truck now was only a few hundred pounds, 500 tops.
  11. Flipflops
    Flipflops Heavy Load Member
    734
    965
    Oct 18, 2015
    A friend of mine and I have the same exact truck. Differences are the engines, fuel tanks, and mine has an APU. Our weight difference was about 2,000.
    americanmadetrucker and Bean Jr. Thank this.
