Whats the lightest condo sleeper conventional ever made without considering engine and transmission
Discussion in 'Flatbed Trucking Forum' started by David Schwarz, Dec 16, 2015.
  1. David Schwarz
    David Schwarz Light Load Member
    150
    81
    Dec 16, 2015
    Indiana
    Or to put it more plainly, aside from engine and tranny, what is the lightest condo sleeper truck available to buy, new or old?
  3. Chinatown
    Chinatown Road Train Member
    73,227
    164,410
    Aug 28, 2011
    Henderson, NV & Orient
    Probably those lightweight trucks Prime uses.
  4. KenworthGuyNH
    KenworthGuyNH Road Train Member
    1,050
    2,686
    Dec 11, 2011
    Central, NH
    Frankly, any truck without an engine and transmission is gonna be pretty dang light. You are in the flatbed section. What is the obsession with "light"???
    Highway Sailor, spyder7723 and MJ1657 Thank this.
  5. 201
    201 Road Train Member
    12,042
    24,575
    Apr 16, 2014
    high plains colorado
    If I remember, the Freightliner was the lightest truck I drove. Just curious, why are you cutting it that close with MT weight on truck. When I say it was the lightest, not by much. Tractors( with like equipment)all seemed pretty close in weight.
  6. TB John
    TB John Company Shill of BYOB & CBD
    3,348
    8,105
    Dec 28, 2008
    To save any significant weight with a condo you'd be looking at a single axle.
  7. David Schwarz
    150
    81
    Dec 16, 2015
    Indiana
    There are a lot of loads that won't load you unless you can take 48,000 lbs. I'm only able to do 47,500 now with my freightliner Cascadia malone, and I'd like to buy something lighter.
    Dominick253 Thanks this.
  8. kylefitzy
    kylefitzy Road Train Member
    4,596
    18,980
    Aug 12, 2007
    Kansas city,Mo
    Why not a lighter trailer?
  9. Pool6710
    Pool6710 Medium Load Member
    662
    258
    Aug 10, 2014
    Minnesnowta
    If you have steel rims that's ~250lbs
    And Ss would be about ~500lbs
  10. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    I have a Columbia with condo and full of fuel it scales 19,120 lbs.
    Before this I was in a Pete 386 and while it had smaller 110 gal tanks vsy 150 gal tanks.. it scaled 17440 lbs.
    Both truck have the same engine.. acert C15.
    Hurst
