What's the difference in a lumber tarp and steel tarp?
Discussion in 'Flatbed Trucking Forum' started by ford06, Feb 9, 2019.
  1. ford06
    ford06 Bobtail Member
    39
    13
    Mar 8, 2017
    what is the main differences in the two and what do you all carry with you thanks for the info
    cke Thanks this.
  3. Humblepie
    Humblepie Pontificator
    5,077
    80,318
    Dec 25, 2018
    Size and lumber tarps have flaps for the ends a lot of the time
    cke Thanks this.
  4. adayrider
    adayrider Road Train Member
    1,289
    1,732
    May 7, 2018
    Lumber tarps are very heavy, steel tarps are heavy
    lumber are 24' wide known as 8' drops
    steel are 16" wide known as 4' drops
    both can have flaps
    cke Thanks this.
  5. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    We carried just one set of tarps for everything. Lumber was rarely tarped with one exception. At the Hagerstown Railroad yard where we collected Lowes lumber, we tarped just the expensive asian wood only.
    cke Thanks this.
  6. Kshaw0960
    Kshaw0960 Road Train Member
    1,581
    5,023
    Jun 17, 2018
    Lumber tarps and steel tarps are exactly the same except the size.
    Lumber tarps are typically 24x26 so you can tarp things 8 ft tall. Steel tarps are typically 16x26 so you can tarp things 4 ft high.
    I carry a set of 8 ft and 4 ft drop tarps but I only use 8 ft drop tarps maybe 4-5 times a year. I use my 4 ft drops all the time. I’m tempted to remove my 8ft tarps off the truck.
    cke Thanks this.
  7. spyder7723
    spyder7723 Road Train Member
    15,467
    25,009
    Mar 31, 2013
    sarasota, fl
    Most folks call 8 ft tarps lumber tarps. But its really about what they are designed to cover which dictates what they are made out of.
    Doughboy18 and cke Thank this.
  8. cke
    cke Road Train Member
    5,857
    71,791
    Aug 4, 2013
    Colfax Wi
    About 300 pounds is the difference. I carry both
  9. Zeviander
    Zeviander Road Train Member
    4,887
    36,995
    Jan 23, 2015
    Winnipeg, MB, CA
    Unless you like wrapping Christmas gifts, you won't want to use lumber tarps on steel, unless it's tube more than 3-4 off the deck.
    staceydude Thanks this.
