Whats the advantage/differnce of split axle trailers vs tandom axle trailers?
Discussion in 'Questions From New Drivers' started by Bazerk Wizz Bang!, Nov 30, 2010.
  1. Bazerk Wizz Bang!
    Bazerk Wizz Bang! Medium Load Member
    Saw a shiny chrome trailer, chrome top to bottem even chrome reefer with split axle's at walmart being towed by a nicely decked out truck awhile ago. I saw the trucker inside and asked him about why he went with a split axle no reall reason, just curios. His response was something like: "Man becouse it like totality looks so much cooler than those other trailers man" ask him what the difference was, same basic response "I dont know but it looks cool man" something like that.
    Got me wondering though. I see all flatbeds have split axle's, a lot of the moving vans have them, but most of the dry vans run sliding tandoms, and almost all reefer use sliding tandoms. Why dont flatbeds use sliding tandoms, or visa-versa. With sliding tandoms you can easily adjust your weight, why would some one want there axles to be fixed? On the split axle trailers can you slide one axle or another or are they fixed?
  3. bulldozerbert
    bulldozerbert Medium Load Member
    622
    240
    Oct 5, 2008
    Ontario
    do you think it has to do with weight? and state regulations??
    there is a discussion on here "somewhere" about it. one of those guys will post actual facts.
    I think if I remember correctly, they can put 40,000 pounds on the spread axle.
  4. Flying Dutchman
    Flying Dutchman Road Train Member
    1,274
    522
    Nov 2, 2009
    Northern California
    tandems are good for 34k lbs, separate axles are good for 20k each
  5. Flying Dutchman is right. Because the axles are 10"2" apart they are considered single axles and you can run 20k on each. When you're hauling 48,000 single coils and such you don't have to be precise on the placement of the coil, the spread axle configuration is very forgiving!!! Plus they ride nice.
  6. ChromeDome
    ChromeDome Road Train Member
    3,706
    2,086
    Jun 10, 2007
    Lakeland, FL
    Also, the spread axle reefers that you see are mostly 48 foot trailers. So they are a little shorter. Goes well with a long wheelbase truck, especially if you have a dump on the back axle. You can back that trailer into any hole without much problem, once you have a little practice.
  7. Kenworth_Trucker
    Kenworth_Trucker Bobtail Member
    43
    8
    Nov 23, 2010
    I have always preferred them , but thats me.
  8. Skunk_Truck_2590
    Skunk_Truck_2590 Road Train Member
    2,094
    684
    Feb 16, 2007
    Stonewall, LA.
    Might ride better and help with weight but backing into a hole is a bigger pain in the ### and they eat up tires too!
  9. Jack Smithton
    Jack Smithton Light Load Member
    255
    167
    Jan 1, 2009
    so cal
    What about the California 40-foot kingpin-to-center-of-rear axle rule? How does that work? I asked some driver in Arizona, and all he could tell me was "I don't run in California" (A pretty good idea).
  10. Skunk_Truck_2590
    2,094
    684
    Feb 16, 2007
    Stonewall, LA.
    I refuse load's going anywhere in Cali, Boston, or NYC (unless passing through on I-95) or Canada. Other than that I'll go anywhere. I'm not sure about the 40' to center rule there concerning spreads. I know they have a lot of spread axle refer's running around there. Note that some spread axle refers are set up to slide where a single axle can be slid independantly or both together as a set.
