What's asphalt hauling like?
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by speedyk, Oct 20, 2019.
  1. speedyk
    speedyk Road Train Member
    1,837
    2,470
    Apr 8, 2015
    What does the loading and unloading process involve? I'm guessing it's daylight if local?
    FlaSwampRat Thanks this.
  3. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
  4. Tb0n3
    Tb0n3 Road Train Member
    4,278
    8,194
    Oct 5, 2012
    Earth
    I've only ever done it in the Northeast so keep that in mind. The silos they mid into will typically have an air operated spout and usually, but not always, you'll be on a scale to get an accurate read. They'll want it tarped, and if it's raining you'll likely have to have extra flaps on a dump truck to secure. For us it's all end dump into a paver or an MTV that stores up to 50 tons and feeds the paver. While dumping here you'll ride on rollers in the paver until you're done, then move to a clean out before it cools and freezes on the truck. It's hot, but not terrible with boots and regular gloves with the batting on the palms. In other areas I know they operate belly dumps that lay the mix out in a path before the paver. That's probably a bit easier, but you have to move while dumping to spread properly.
    FlaSwampRat and speedyk Thank this.
  5. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    Lots of night paving around the larger cities.......
    Mostly by the hour, no off roading to beat up the truck.
    I like it ..... but that’s me...:-/
  6. speedyk
    1,837
    2,470
    Apr 8, 2015
    How does asphalt get transported in a tanker? Is it fluid?
  7. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    310F liquid..... it’s like the viscosity of cold 90 weight gear oil.
    You don’t want to get it on you.... it’s what I do......
    FlaSwampRat, speedyk and Tb0n3 Thank this.
  8. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    This is how we do it around here.
  9. Tb0n3
    4,278
    8,194
    Oct 5, 2012
    Earth
    Why do all the triaxle guys get a hard-on over R-model Mack's?
  10. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    It’s like your first car...... all of us old construction drivers had Mack’s ......
    Trying to relive the glory days......
  11. JonJon78
    JonJon78 Road Train Member
    7,041
    37,549
    Jul 1, 2018
    Is the dump truck in neutral being pushed by the paving machine or hes in gear creeping along?
