Whatever happened to landing gear with rollers?
Discussion in 'Questions From New Drivers' started by TomCougar, Dec 9, 2019.
  1. TomCougar
    TomCougar Light Load Member
    180
    146
    Sep 4, 2019
    Lawton, OK
    There used to be a time, the 20th century, where landing gear for trailers with airplane style wheels on them was common. What were these wheels for? What was the proper name for them? Why do they seem no longer in existence?
    Mack Trucks "YEARS"
    mp4694330 and scottied67 Thank this.
  3. DougA
    DougA Road Train Member
    1,429
    8,892
    Dec 16, 2013
    Retired,In my shop in Md.
    Used to call them landing gear dolly wheels. You always had to hook your airlines up first,and charge your trailer brakes,before hooking to the trailer. Otherwise you'd be chasing the trailer around in reverse,trying to get it up on the fifth wheel. 99% of those old trailers didn't have maxis,and the air would leak off and they'd just roll around when you tried to hook up.
  4. Moose1958
    Moose1958 Road Train Member
    15,255
    33,805
    Dec 17, 2010
    Williesburg, Virignia
    With this industry going to a drop and hook system, more and more trailers are sitting loaded. I would imagine one problem with this style of landing gear would be a tendency for it sink in the soft ground much easier than a landing gear with a large plate at the bottom.
    Forgive me, I can't understand your point about "chasing the trailer". I'm not a mechanic but I was under the impression a trailer spring brakes did NOT need to be "charged" to hold while backing under it. Also if the driver is correctly backing under the 5th-wheel is raising the landing gear off the ground a bit as it goes back.
    FlaSwampRat Thanks this.
  5. wichris
    wichris Road Train Member
    4,424
    9,053
    Jan 17, 2011
    Older trailers didn't have spring brakes.
    bzinger, Dennixx, okiedokie and 5 others Thank this.
  6. AModelCat
    161,266
    No spring brakes on old trailers, just service pots. You "dynamited" them. There's a special relay valve on those old trailers called a relay-emergency valve. Its purpose is to put full trailer reservoir pressure to the service brakes when pressure is exhausted from the trailer supply line.
    baha, Suspect Zero, not4hire and 2 others Thank this.
  7. wichris
    4,424
    9,053
    Jan 17, 2011
    Red, Yellow and Blue buttons.
    baha, bzinger, okiedokie and 2 others Thank this.
  8. AModelCat
    161,266
    You don't need the blue button to pull an old trailer without spring brakes though.
  9. wichris
    4,424
    9,053
    Jan 17, 2011
    I know. Just something else that many have never seen.
    FlaSwampRat and AModelCat Thank this.
  10. kemosabi49
    10,900
    47,282
    Jan 13, 2013
    SW Arkansas
    Spring brake became a requirement in 1975. I worked loading sheetrock for years and sometimes we had to move trailers around with a forklift. Spring brakes stopped that.
    bzinger and FlaSwampRat Thank this.
  11. AModelCat
    161,266
    I often wonder if pole-type log trailers were exempt from that ruling. I've seen some built up until the mid 90's with just service pots on every axle.
