What you use to separate your dual wheel when they are stuck together ?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by sunsation288, Mar 15, 2014.
  1. sunsation288
    sunsation288 Light Load Member
    55
    54
    Jan 12, 2014
  3. upallnite
    upallnite Light Load Member
    165
    115
    May 15, 2010
    Hempstead,TX
    use the plastic spacer they put between aluminum and steel rims, or smear anti-seize on the contact surface before installing. this has worked well for me.
  4. freightlinerman
    freightlinerman Road Train Member
    1,287
    536
    Mar 4, 2011
    Florida
    Have you tried a sledge hammer and beating them? Spraying a lubricant on the hubs so they slide or in between? Putting a rope or chain between the hand hole and gently pulling?
  5. Dickeyroberts
    Dickeyroberts Light Load Member
    138
    30
    Feb 23, 2014
    Anti seize works great. Had the same problem with my wheels.
  6. that65
    that65 Light Load Member
    185
    84
    Jan 16, 2012
    Lincoln,Ne.
    A gallon of gasoline and a match.... works every time..
  7. mtoo
    mtoo Road Train Member
    1,928
    4,427
    Jan 15, 2011
    Retired on bended knee
    A whole gallon seems over kill. I think a quart would do:Oil::biggrin_25520:
    that65 Thanks this.
  8. Flightline
    Flightline Road Train Member
    2,345
    1,165
    Oct 1, 2011
    Almost There
    I find antiseize only works if put on previously.
    Cetane+ and Heavyd Thank this.
  9. mtoo
    1,928
    4,427
    Jan 15, 2011
    I wish the truck manufactures would use anti seize when they put the trucks together. Sure would make life easier owning an older truck.
    Heavyd and that65 Thank this.
  10. Meskie
    Meskie Bobtail Member
    13
    7
    Apr 8, 2009
    Saskatoon Saskatchewan
    I normally use a BFH
  11. jameslawton
    jameslawton Light Load Member
    257
    65
    May 1, 2013
    Tulsa OK
    I put on 4 lug nuts pretty loose set the truck down and pull it forward and back they will come loose
