what you guys think about blowing air in air filters to clean
Discussion in 'Trucks [ Eighteen Wheelers ]' started by shawn_ca, Dec 16, 2013.
  1. shawn_ca
    shawn_ca Light Load Member
    126
    14
    Jun 21, 2012
    Los Angeles, CA
    hi,
    I was getting my trucks oil changed and air filter was dirty , i asked the mechanic to replace it but they didn't have one in stock so he suggested and blow air in it to clean it out and suggested to wait for next oil change and then we can replace new air filter .
    Is that a good idea or will it harm engine anyway when air filter is dirty and was cleaned by blowing air in it to clean up a bit .
    I noticed that at few places where they dont' put new air filters and just clean it with air gun , someone told me that this way is more damage to the truck.
  3. "Hang - Man"
    "Hang - Man" Heavy Load Member
    737
    583
    Nov 12, 2013
    Western PA
    It is always better to have maximum air flow (New) --it wont damage your truck but just impede airflow.
    Can you pull it out and hold it up to a light or the sun ? Just see if you can see light through it and if you can its clean enough to use till you get time or get a new one.
    shawn_ca Thanks this.
  4. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,116
    May 19, 2011
    Just leave it in there and change it the next time, using shop air to clean a filter is a bad idea, you can weaken the paper element and allow dirt to pass thru it into the engine.
    wore out, 123456, shawn_ca and 3 others Thank this.
  5. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    very bad idea. it will loosen all the dust particles & they WILL get into engine.
    123456 and shawn_ca Thank this.
  6. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    If one is bound and determined to blow air to clean an air filter, the best way I have seen that does a decent job and will not risk damage to the filter is using one of those cans of air you can buy at Walmart in the electronics section. Shop air is too high pressure, unless you can get it down below 20 psi. I have several air filters in other vehicles/equipment, that are designed to be cleaned out a couple of times before replacing. The maker recommends using air pressure lower than 20 psi. I find the canned air works pretty good for that purpose. I just tap the filter to loosen up the stuff between the pleats and then blow it out with the canned air.
  7. dannythetrucker
    dannythetrucker Road Train Member
    2,856
    4,032
    May 26, 2011
    everywhere, man
    My opinion is it's a good idea to blow out air filters. Not instead of replacing, but in between when in dusty environments. True, if the filter is full of dirt you will damage the paper trying to blow it out. That is when you should be replacing filter.
    However, whenever you go through a dusty environment there will be much dust simply sucked to the outside, not permeating the paper. A quick blow from the inside out and a few quick strokes down the outside will get rid of 90% of it. Do not blow from the outside in, do not hold air too close to paper.
    Personally, I would prefer that dust to be left on the ground rather than caking the outside of my filter and I believe you can do it safely. I know plenty of farmers who do this on a daily maint procedure in dusty fields and have not heard any account of damaging engine. I believe that is a line told by folks who sell filters.
    puncher, "Hang - Man" and lester Thank this.
  8. fuzzeymateo
    fuzzeymateo Heavy Load Member
    771
    783
    May 20, 2013
    AZ
    In the military we were taught to do this often, especially in desert environments. I worked for a sod company here in AZ for years and we were loading off of farms in central AZ every day. The dust down here is a very fine powder and would clog air filters almost daily. It wouldn't make sense to replace them on a weekly basis so every week I would remove the filters and blow them out with shop air. I would notice a substantial increase in performance after blowing the filters out. I see no problem doing it as long as you are careful.
  9. wore out
    wore out Numbered Classic
    15,942
    192,918
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Bear in mind every time you remove and and clean the air filter then reinstall, it is hard on the seal. I have seen more engines dusted by too high of air pressure tear the element or it was blown out and reinstalled till the seal is no longer tight. If a restriction indicator is used and maintained you know when to replace them. I have been on jobs the air filter in the machines were replaced every other day it was so bad. When we got the pencil pushers to listen and we quit blowing them out we quit losing engines.
    Cetane+ and fuzzeymateo Thank this.
  10. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    Blow the filter from the inside out.
    Better yet, find a level and clean surface. Tap the filter on the ground, then rotate a little, and keep repeating. You won't need any air. Most of the dirt will fall out ;)
    puncher Thanks this.
  11. Cowpie1
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    This is why it is a good practice to rub a little vaseline on the seal of the air filter before you mount it. Goes on easy, prevents damage to seal, seals better than the air filter seal by itself, and makes it easy to remove.
    Rodeorowdy, puncher and fuzzeymateo Thank this.
