What would be the best used truck to get for a first time O/O
Discussion in 'Ask An Owner Operator' started by naval_superman, Jan 11, 2017.
  1. naval_superman
    naval_superman Bobtail Member
    21
    6
    May 24, 2016
    I'm thinking of becoming an O/O here in a few months and hit the road for a while. I'm looking for a good reliable used truck and want to know what brand/type of truck would be best for a first timer (maintenance cost, reliability, fuel mileage, etc.). In all honesty I'm really attracted to the "square nosed" type trucks like the 379 and W900, but know price wise are very expensive. I saw somewhere that freightliners are very reliable so would getting a used freightliner classic be a good choice? Any info and opinions would help. Not making any decisions anytime soon, just want to shop around the market a bit and get an idea what to look for. Thanks
  3. Dryver
    Dryver Road Train Member
    2,818
    2,575
    Nov 30, 2008
    Sioux Falls, SD
    Forget what you are attracted to and go with the most EFFICIENT truck you can afford. The W900 can wait until you have your head above water and money in the bank. Also, you cant pick a truck until you know what you will be hauling because you have to spec the truck to the intended use. Reliability comes with service and who did it, service records are golden.
    Today, I would shop for a pre emmision Freightliner with Detroit and 13spd.
  4. tbdieseltrucking
    tbdieseltrucking Light Load Member
    100
    60
    Jan 4, 2017
    Stuck in a Rut
    My first truck was paid for in cash. It was an '89, that I bought in 2004. Ran it local/regional, and then traded up. Still local/regional, but driving a 2017. As @Dryver said, you need to know what kind of work you will be doing first. Forget about shiny chrome and paint....look at the motor, rear ends, FRAME, get an oil sample, and maintenance records. Starting out, try to get something pre emission and mechanical...easier to work on. Just remember, MOST, not all used trucks are priced higher than the market because of emissions and E-logs. Do some homework, price it out...insurance and everything...and ASK. There is a s#it ton to know, you won't get it all day one. Been in a truck since 1998, and still learning. Good Luck.
    Dryver Thanks this.
  5. Eddiec
    Eddiec Road Train Member
    2,191
    3,358
    Feb 2, 2015
    Know what the job is before you buy the truck. Are you going to lease on with someone? So how old of a truck will they take? What about insurance? Once you narrow your choices down... then you can start specing out a truck for the job. You can Go to truck paper .com and spec the truck all the way to the sleepr size. Then you need to do all the stuff that tbdieseltrucking said, plus a rigdig report and download the ecm history! It is a lot of leg work, but a whole lot cheaper than a bad purchase. Good luck!
  6. Ridgeline
    22,101
    113,189
    Don't forget about the Dyno and the blowby.
  7. naval_superman
    21
    6
    May 24, 2016
    Thanks everyone for your advice really all good stuff.
    I'd want to lease onto someone, not from. And I want to haul dry van. Been driving for a year now and just would like to get my feet wet into the O/O life, but don't want to go full indepent until I know what I'm doing.
    tbdieseltrucking Thanks this.
  8. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    The truck you need, is not always the truck you want.
    Just look at my sig as an example. Ugly as sin,.. but its been a good money maker. Think of the truck as a tool needed in order to do a job. Whats the best tool you can have? Affordable and reliable are the 2 main things I look for.
    Cash is king,.. credit can be a double edged sword. Only use that route if you know and understand the business side of trucking. Else do yourself a favor,. and just wait until you have enough cash to do what you need. By the time you have the cash saved up, if you did your homework you will know everything you need and the rest will come through trial and error.
    Best of luck to you!
    Hurst
    tbdieseltrucking and AModelCat Thank this.
  9. blairandgretchen
    13,212
    70,208
    Dec 9, 2011
    South west Missouri
    You want to haul anything else but dry van.
    Keep researching and asking. You'll get there with a good plan.
    Good luck.
    And my pick is pre 2003, anything. Spec'ed for what your business plan says you will haul, and for whom.
  10. akfisher
    akfisher Road Train Member
    1,023
    950
    Apr 23, 2015
    Freightliner glider with a 60series detroit
  11. blairandgretchen
    13,212
    70,208
    Dec 9, 2011
    South west Missouri
    But check Fitzgerald very carefully, many problems.
    Hurst and tbdieseltrucking Thank this.
