What would be a good reach pole for Roll door trailers and pups.
Discussion in 'Questions From New Drivers' started by TruckerDanINDY, May 29, 2022.
  1. TruckerDanINDY
    TruckerDanINDY Bobtail Member
    May 29, 2022
    Hello I'm starting a job with FedEx, and im a bit on the bigger side... So I was wondering if anyone could recommend a good reach pole or something for being able to reach the strap on the doors to pull them down.
    Chinatown Thanks this.
  3. Suspect Zero
    Suspect Zero Road Train Member
    2,497
    9,423
    Oct 10, 2016
    Burbank, IL
    Not familiar with roll up door trailers, would a 5th wheel puller be long enough to snag the strap with the hook on the end?
  4. Val_Caldera
    Val_Caldera Road Train Member
    2,569
    7,934
    Apr 2, 2021
    TARHEEL
    NOT From The Ground, Only From Dock.
    Roll Up Doors Were "Fun" Yet Not Much When They Weren't.
    Suspect Zero Thanks this.
  5. TruckerDanINDY
    May 29, 2022
    im thinking I would need around a 6ft pole... and im pretty sure those are only around 3 or 4 foot. otherwise yeah it would work.
  6. TruckerDanINDY
    May 29, 2022
    Roll up doors are nice when you ant gotta shut them... Just back that badboy into the dock, dont even gotta worry about opening doors.
    Bean Jr. Thanks this.
  7. Arctic_fox
    3,861
    19,402
    Sep 16, 2016
    Broom handle with a hook on the end. They sell threaded addapters at most hardware places.
    Otherwise a colapseable hook works well. Or a boathook.
    Flat Earth Trucker and Magoo1968 Thank this.
  8. tscottme
    tscottme Road Train Member
    5th wheel pin puller. The chrome ones with a hook facing 2 different directions are probably 4-5 feet long. Or you can just buy or make something for $10 from the hobby wood, PVC, or aluminum or steel threaded rod/bar stock from Lowes or Home Depot.
    Lav-25 and Flat Earth Trucker Thank this.
  9. Hawkeye72
    Hawkeye72 Light Load Member
    264
    805
    Feb 20, 2015
    Iowa
    Dock hook. At my center most drivers grab one while getting straps. I think thats why some centers cable them to the dock.
    If you are working for freight you need to get used to climbing into trailer from the ground. You will be doing it a few times a day.
    tscottme Thanks this.
