I wanna rewire '03 century, and what gauge wire to use for battery, starter?
I know, thiker is better)
What wire to use for batteries...
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Pablo-UA, Dec 17, 2010.
2/0 cable, per set of two batteries If you have three use two cables or one 1/0. I prefer using 2/0 and solder the conecsions. Crimping, to me is a problem looking for a place to happen. Running extra ground cables frame to engine on the right side is also a good idea.
If you have a multimeter check grounds extras to the cab works wonders. -
4/0 For Batteries and Starters and here is why. The Bigger the gauge the Less Resistance to flow that plus if it is a Centry with the Batteries back inbetween the Frame Rails you will need it for the Length of run you will have to prevent a Voltage Drop.
Excellent advice from both previous responses. I am overkill on my electrics. I use 2/0 between batts and two of the three grounds(One ground to motor, one to frame and 1/0 to cab) . I use 4/0 to starter. Excessive, i know but i think it is worth the money and pain running it through truck(the stuff is brutally thick). And as John said, solder connectors!
One thing i firmly believe in and didnt see mentioned... Use adhesive heat shrink to seal connections. I use both red and black to quickly indentify connections. And it makes for a very neat and professional looking job and helps prevent electric problems down the road imo... -
Thanx for advice! I wanna use welding machine cabels, inch of diameter... )
I agree with 4/0 for main cables to starter, 2/0 for battery to battery jumpers.
You do realise that 4/0 is small cable used for gas motors.
Battery cabble is bigger the smaller the number.
Welding cable is not good for use as battery cable. -
Refers to the copper conductor size, according to the American Wire
Gauge, based on the conductor's circular mil area. Gauge numbers
decrease as wire size increases, e.g. #8 is smaller than #6, etc.25(2)+2 Thanks this. -
i had some cables made by this guy, imo the best you can find at reasonable prices
wire gauge chart
http://custombatterycables.com/technical_data.htm
what size to use
http://custombatterycables.com/what_size_cable_do_you_need.htm25(2)+2 Thanks this.
