What turbo to replace isx variable turbo with?
Discussion in 'Peterbilt Forum' started by MARK AT PIMCO TRANS, Mar 7, 2012.
  1. MARK AT PIMCO TRANS
    MARK AT PIMCO TRANS Bobtail Member
    19
    9
    Dec 27, 2011
    SAN ANGELO,TX
    Hello. I have a 08 386 Pete ISX Cummins that I am "fixing" the emissions equipment on, but it also has a bad stock variable turbo. Does anyone know of a replacement turbo that will bolt onto the stock exhaust manifold? Not really looking for more performance mainly reliabilty. And a lesser price than the stocker variable turbo$$$$ would be nice. Thanks.
  3. The Admiral
    The Admiral Heavy Load Member
    894
    561
    Jul 18, 2010
    Akron,Ohio
    If you go to the regular 18 wheeler forum you will get more responce. Also there are numerous threads with your answer. Mr. Haney is the answer man. Also is a PDI dealer. He can get you straightened out.
    MARK AT PIMCO TRANS Thanks this.
  4. Graglor
    Graglor Light Load Member
    62
    15
    Aug 17, 2011
    Langley, bc.
    If you put in anything else your. Heck emngine light will be On all the time. You sure it's not the turbo actuator switch/sensor?
  5. Graglor
    62
    15
    Aug 17, 2011
    Langley, bc.
    The sensor is on the drivers side of the engine towArds the back. I know that sounds like it doesn't make sense, but it's there. Cheap and easy to replace!!!
  6. Graglor
    62
    15
    Aug 17, 2011
    Langley, bc.
    Sorry for the bad typing lol.
    I've had this before so I'll save you the head ache that cummins might put you through. There is a signal line from the exhaust manifold that goes around the engine to the drivers side and to the actuator which engages the veins of the turbo.
    If the actuator fails the code is the turbo when in reality it's not.
  7. PeteVolvo tech
    PeteVolvo tech Bobtail Member
    33
    12
    Mar 23, 2012
    WI
    I would just put a stock 99-02 turbo and manifold on it. Then where ever you are hauling if you do have any issues it will not be hard to find replacment parts. Sometimes the down time waiting for replacment aftermarket parts kills guys even if there under warranty.
  8. MARK AT PIMCO TRANS
    19
    9
    Dec 27, 2011
    SAN ANGELO,TX
    ended up just putting new stocker on due to time restraints. truck is fixed. thanks.
