What truck would you Spec for hauling Logs in South Georgia?
Discussion in 'Mack Forum' started by Erictanker, Jan 5, 2019.
  1. Erictanker
    Erictanker Light Load Member
    58
    19
    Dec 22, 2018
    Wrightsville, Ga
    What’s the best spec set up for logging in South Georgia??? I’m thinking like 18k front axel what’s highest rear in tandem? How is mad clearance heights? What else should I consider?
  3. AModelCat
    154,278
    If there's off road work around there I'd get 46k rears and heavy duty air ride. Definitely full lockers too.
    Erictanker Thanks this.
  4. Erictanker
    58
    19
    Dec 22, 2018
    Wrightsville, Ga
    How and when do you use full locking ??
  5. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    I have 46,000 with full lockers.
    Helps to get you going when fully loaded on soft ground. It takes an awfully lot of torque to launch the truck out in the dirt.
    I had a set of 40,000 lbs rears , after only two years of that kind of work, the bearings gave out on the front diff
  6. Humblepie
    Humblepie Pontificator
    5,077
    80,318
    Dec 25, 2018
    In sc. the typical spec is 14k front 46 rears. Not many run 18 to 20k steers unless the truck pulls double duty pulling a lowboy. But there are are a heap with 12/40.
  7. Erictanker
    58
    19
    Dec 22, 2018
    Wrightsville, Ga
    What type truck u use????
  8. Gdog66223
    Gdog66223 Road Train Member
    1,871
    2,568
    Dec 30, 2017
    Coal Town
    You've got like 3 threads dedicated to logging... you got the fever bad don't you... did you ever buy a truck yet?
    Humblepie Thanks this.
  9. Erictanker
    58
    19
    Dec 22, 2018
    Wrightsville, Ga
    Naw I’m just trying to learn I’m thinking about it tho lol!!!!
  10. Gdog66223
    1,871
    2,568
    Dec 30, 2017
    Coal Town
    Well your not losing any money by thinking about it so think away..
    Erictanker and not4hire Thank this.
  11. AModelCat
    154,278
    Up on the west coast it seems Western Star and Kenworth are the king in the bush. Do see the odd HD Freightliner too. Logging needs a different breed of truck than a typical door slammer specs.
