What batteries do you guys recommend for a group 31, our douglas batteries are constantly in need of replacement after 12-15 months in every one of our trucks- we use a 3 battery setup the trucks are slip seated daily, are daycabs and we haul fuel, with about 10-12 startups a day
What Truck Batteries Do You Recommend?
Discussion in 'Peterbilt Forum' started by dcwjr, Dec 2, 2014.
Probably not enough time to fully charge making all those stops. Bigger alternator would help. Over the road truck batteries take a long time to charge since we drive for many hours every day. Maybe you have the wrong type of battery in there. I think a day cab would use different type then us.
Perhaps, the Maxwell UltraCapacitor will extend the life of your batteries. i.e. by not using a battery for start up. My current batteries are off the shelf by Freightliner's Alliance parts, AGM Group 31. Originally purchased, Feb.2011.
A 06,changed the 2 batteries just before the winter off 11.
They were still working but didn't want to risk a breakdown.(i noticed the truck didn't start as smoothly as it should)
I start it around 40 to 50 times a day.
And before anyone calls BS on this,i will add that my truck runs 24 volt. -
How you mount the batteries has a lot to do with life expectancy.Vibration is bad for a battery. Keep that alternator set right, the terminals clean, have a piece of plywood under them, wash them off every so often,keep them all the same size and style, and keep your truck tuned to start easy.I always run 4 batteries, 3 will get you in trouble and leave you sitting.
Sometimes I think it just plain luck when a battery lasts a long time. I have had cheap ones last a long time, and high dollar ones give up in less than a year."semi" retired Thanks this. -
Thermoking Eon
http://megaholod.net/offers_articles/tk/0042.pdfLucar Thanks this. -
2 questions for the OP
1°do you have to top off the fluid much?
2°has anyone checked how hot the batteries are running during the course off a shift? -
Maybe when getting serviced put a charger on them to get a deeper charge ... Or keep some spares charged up with a slow charge and swap out every 6 months or so ... Every 2 or 3 months I give mine a slow charge and they normally go 30 plus months even with heavy bunk heater and invertor usage ..
