What towing capacity is best for a hotshotting truck?
Discussion in 'Expediter and Hot Shot Trucking Forum' started by ebucher96, Mar 12, 2010.
  1. ebucher96
    ebucher96 Light Load Member
    51
    7
    Aug 7, 2009
    Woodward, OK
    I'm looking for a personal truck/part time hotshotter. What towing capacity should I look for? Does the truck/trailer combo need to stay under 26k? Looking to buy a new truck and want to make sure I get the best one for what I am looking for. This will be my personal truck but I want to hotshot part-time, probably with a 40 foot flatbed that I already have. Also, is there anything else that I am not thinking of? I already have my own authority so more looking for just the actual truck info. Any help would be appreciated.....
  3. grimesjm1
    grimesjm1 Medium Load Member
    375
    228
    Nov 5, 2008
    Kensington,OH
    i'd get one of those chevy kodiaks. u need a cdl but for the money you'll have twice the truck as a one ton dually.
  4. buckshot2104
    buckshot2104 Bobtail Member
    21
    9
    Jan 31, 2009
    benton city washington
    you will need a class a cdl if the truck and trailer have a gvw over 26000 lbs. there is lots of options out there the f550 or f650.
  5. statikuz
    statikuz Medium Load Member
    401
    140
    Jun 22, 2009
    Reno Nevada
    We had some hotshot guys bring some material to my job. Here's some crappy cell phone pics of their truck:
  6. ebucher96
    51
    7
    Aug 7, 2009
    Woodward, OK
    I will have to look at that Kodiak. Most of the trucks I look at only tow about 13k, is that normal for hotshotting or would I be better with a higher towing capacity? As far as the F550, we have a 2008 model and it has been in the shop about 85% of the time in the last 5 months. That is one of the reasons that I'm looking for another. Thanks for all the input guys, the discussion helps with my search alot....
  7. phroziac
    phroziac Road Train Member
    3,138
    502
    Jun 16, 2009
    Gary, IN
    Honestly I see a lot of hotshotters with obviously overloaded trucks, obviously it works for them.
    I've seen f-350s pullin 8 car trailers
    if its more than 26000 lb you need a lot more than a cdl. you'll need a logboook.....
  8. LBZ
    LBZ Road Train Member
    1,771
    1,266
    Oct 22, 2008
    Road to Nowhere
    I do not believe you saw a one ton pulling an 8 car trailer. 8 car high mount trailers are pushing the 20,000 pound mark completely empty. There are two companies out there marketing a 5 car trailer for one tons & even at that, they are beyond overload. One thing to get something moving, completely different to stop it with electric type brakes those trailers have.
    A majority of one ton with either flat or wedge trailer set ups are plated for 36,000 lbs. The drive axle is overloaded most times, the biggest scare is brakes & yes you will need everything the big trucks need to be legal i.e. IRP, IFTA, CDL, log book, Commercial Insurance, Med card etc.
  9. Kansas
    Kansas Road Train Member
    2,541
    2,585
    Apr 14, 2009
    aircap, Ks.
    Kodiak and/or F650 will blow you right over the 26K limit you were talking about.
    Generally speaking F550's are made to haul. F450's are made to tow.
    Personally I wouldn't touch a Ford with a 6.0 or 6.4 with a 10' stick right now. It pains me to say that as I am 100% a Ford fan, but right now I'd have to buy a Dodge.
    What do you "think" you're gaining by staying under 26K. You still have to have a CDL, a physical card, and you're still going to run a log book.
    If you're truly going to do this full time I would be looking at least in the F450 or 4500 range. You get bigger brakes, heavier suspension, and a tougher frame. The down size, you'll end up with 4.30 or 4.88 gears, which I do not like, but those can be changed. And, as long as your doing all that, you gotta sleep somewhere so ya might as well just go all-in and get a big truck with a sleeper...
  10. Roadmedic
    Roadmedic Road Train Member
    18,951
    8,980
    Apr 4, 2007
    CDL is not required until the 26,000 lbs is met. However, medical card and log book are required at 10,001 lbs.
  11. Kansas
    2,541
    2,585
    Apr 14, 2009
    aircap, Ks.
    For what we are discussing the key is what the trailers will be rated at over 10001. He needs a CDL.
    If the trailer is rated 10001+ you need a CDL period.
    I guess if he's gonna haul a two car trailer with a single 10K axle or two 5K axles, with an F250 he wont need a CDL. Any more than that, and you fall into CDL territory. Same trailer but with a dually pickup, and your gonna cross that weight barrier.
    Being realistic. My guess is he's looking at 3 car wedges, which fall into CDL territory, ain't no ifs, and, or buts about it. 3 7K axles or two 10K tandem duals puts you over 10001. You need a CDL.
