What tires?
Discussion in 'Ask An Owner Operator' started by Highrisk21, Sep 15, 2016.
  1. Highrisk21
    Highrisk21 Light Load Member
    132
    63
    Aug 22, 2016
    What tires you guys running out there? I have 295/75/22.5 G395 LHS goodyear fuel max on my steers and goodyear G362 LHD 28/32 tread depth on the drives. I can get these again for around $325 per tire so about $3,250 or the tire man is telling me how much better and longer lasting these bridgestone M726EL drives and R283A steers are. The drives new are 32/32 tread depth which is impressive but they are also about $450 per drive tire and the steers are about $475. So thats $4,550 VS. $3,250 ===$1,300 difference. Does anybody know if this major price difference is worth it? Do these bridgestones actually last longer do to the insane tread depth? Or should i just stick with the goodyears and buy some chrome and led's with the 1,300? "not really"
    Any info will be appreciated.
    Thanks
    SimpleTrucker and FL450 Thank this.
  3. Tombstone
    Tombstone Light Load Member
    102
    83
    Jan 29, 2014
    Houston, TX
    I replaced my 8 drive tires 3 weeks ago with Bridgestone M726EL. Maybe it's too early to talk about but tires are amazing. I made a big research before I decided to get those. I also have Bridgestone 283Eco on my steer. 726EL has 32/32 and offers great traction with longer life. However just reminding, 726EL is not one of those fuel efficient and carb complaint tires. So far, Im really happy about my purchase.
    FL450 and Highrisk21 Thank this.
  4. Highrisk21
    132
    63
    Aug 22, 2016
    I've been trying to read up on the 726EL and I found a guy on YouTube that made videos with a tire depth gauge showing all tires and showing the mileage on the dash of his truck and over almost 2 year period he drove about 150,000 miles and his tread depth was between 19-22/32 and his first video they were 32/32 like you said. Although he did have to replace the steers but I thought that was pretty good.
    Tombstone and FL450 Thank this.
  5. boneebone
    boneebone Road Train Member
    2,294
    2,365
    Mar 13, 2009
    Great choice, I've been running Bridgestone M726 and M726EL's for the past 15 years and I won't put anything else on the Drives.
    They last a long time and even if the Rolling Resistance is higher then say a M710 Ecopia, the longer tire life makes up the difference in savings as the M710 or most Eco tires don't last as long as a M726EL will.
    I also have R283 Ecopia on the Steers and they are wearing and performing nicely, they are just as good as the Michelin XZA3+.
    Goodyear Truck Tires are not that good as the Bridgestone tire, sure you may save some money at purchase time, but they will not last as long as a Bridgestone as they do not wear well and need to be pulled off the truck way before the end of their Service Life.
    Tombstone, FL450 and Highrisk21 Thank this.
  6. Highrisk21
    132
    63
    Aug 22, 2016
    Thanks for your personal experience that's what I was looking for was someone with experience with theses tired. Well so far you and tombstone have me leaning towards spending the extra 1,300 or so.
    Thanks
    FL450 Thanks this.
  7. spyder7723
    spyder7723 Road Train Member
    15,467
    25,009
    Mar 31, 2013
    sarasota, fl
    Something to consider, unless you do a lot of off roading you don't need those aggressive lugs. While the m710 might cost a bit more up front, and not last quite as long, the fuel savings more than offsets that. I never believed tires could make that big of a difference till i tried the low rolling resistance ones for the first time about 12 years ago. I got all the records to support their claims. I picked up almost a full mile to the gallon by going from an aggressive tread to the fuel saving gy 305s. I'm currently running the bridgestone m710. Expecting 400k easy before i got to switch them out. For steers I've found the michelins to be the best, might try bridestones next, but probably not. I got almost 200k on the last set and they still had 10/32nds but had to get a new set when i cut one at a job site. I never got close to that on the goodyears, they always had to come off at 180k.
    double yellow, FL450 and Highrisk21 Thank this.
  8. boneebone
    2,294
    2,365
    Mar 13, 2009
    I just put on a set of M726EL's last summer, not because they wore out, they still had 18/32" of thread left on them.
    They were 7 years old and were starting to crack along the sidewall bead edge from UV Damage, other then that, they were in perfect condition.
    The original M726, (not EL's) before that, had a new thread depth of 30/32", they lasted 4 years and 400k miles and were at 8/32" when I replaced them with the EL's
  9. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    M726el lasts a long time but in snowpack they were poor they had a ton of tread left when we pulled them after getting stuck everywhere doing ltl in poorly maintained yards.. Also the ride is a bit stiffer I found
    FL450 Thanks this.
  10. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    some evidence suggests you have to find out what type of tires your truck likes. :biggrin_25519:
    starmac, rollin coal and spyder7723 Thank this.
  11. spyder7723
    15,467
    25,009
    Mar 31, 2013
    sarasota, fl
    This is absolutely true. It makes no sense to me but its just one of those things that don't add up but it's never the less very true.
