What time zone do you log
Discussion in 'Trucking Industry Regulations' started by LogsRus, May 28, 2007.
  1. LogsRus
    LogsRus Log it Legal
    2,589
    358
    Nov 23, 2006
    Indianapolis, Indiana
    Drivers do you understand you should be logging on your home terminal time.
    Do you know what "home terminal" means? If your home terminal is Indianapolis then you need to be logging Indianapolis, In time. "Most" companies have the home terminal address pre-printed on the log sheet for you which would tell what time zone you need to log. Others might have selections of home terminal addres and some are just cheap and make you fill out the home terminal address. In the last case you need to find out the home terminal address. You should check personally with your log department as noted below to find out what is your home terminal address.
    How does that work for receipts such as Toll, scale etc?
    Well the log auditor SHOULD look at the receipt and say I need to either add , subtract 1 hour or leave it the same make it Oklahoma time.
    When time changes I will post what you need to do in regards to that particular day.
    Officers will sometimes write you up for logging the wrong time zone because it makes your logs off by 1 hour or more (if your company allows you 30 minute lee-way, this makes your logs off 1.5 hours in DOT's eyes). They have told my drivers sometimes that you should be logging where you are dispatched out of and that is not TRUE!
    Ok I hope this helps someone before they get busted:yes2557:
    A few tips: Make sure you set the watch on the wrist to the time zone you should be logging. It is human nature to look at the watch on your wrist when you want the time, thus causing you to log the wrong time zone. Also try to avoid filling out the log grid part in a truck stop etc. It is also human nature to look at the clock on the wall since it is bigger.
    Ok that's about the best tips I can give you on what time zone you should log and tips on how to avoid getting messed up.
    The biggest thing is make sure you do not leave 1 hour earlier while on your 10 hour break. I have seen this done as well and driver so happened got pulled over that same day. He was as legal as a begal except for that and he did put him out of service :biggrin_2552:
    New time zone change dates:
    In 2007, daylight time begins on March 11 and ends on November 4.
    Below is a link that has each state listed and when you click on the state each city will be listed below that. If you save this as a favorite you have to make sure you refresh every page when checking out the time zone! I have messed up (sorry drivers) on this before:).
    http://www.timetemperature.com/tzus/time_zone.shtml
    I do want to add a note thanks to Brickman reminding me: There is some companies that have different divisions and break them down. I was just informed below message that Landstar was different and I beleive CRST might be different, although they had 2 different log departments if I am correct. I believe it would have to be different division situations though, because the reg below states the home terminal in which the logs are maintained etc. See below.
    As I can't tell you what time zone to log on, I thought this might help clarify how logs handles the time zone and you should call your log department and ask them :yes2557: They are bored doing logs anyhow.
    f)(8) Time base to be used.
    (f)(8)(i) The driver's duty status record shall be prepared, maintained, and submitted using the time standard in effect at the driver's home terminal, for a 24 hour period beginning with the time specified by the motor carrier for that driver's home terminal
  3. Brickman
    Brickman Trucker Forum STAFF Staff Member
    12,907
    12,209
    Sep 17, 2006
    WY
    Depending on the type of lease operation you are running you log your HOME time zone. Or thats what Landstar wants, even tho the log department is in FL.
  4. LogsRus
    2,589
    358
    Nov 23, 2006
    I will edit my post! Yeah I wanted to note something about different situations as in Lease operations. I am not to familiar with that and how it works, but I do have a small clue.
    THanks Brickman I will add a different little note.
  5. Brickman
    12,907
    12,209
    Sep 17, 2006
    WY
    No problem, I didn't want to confuse any body.
  6. LeadfootSlider
    LeadfootSlider <strong>Queen of the Confused</strong>
    170
    39
    Jul 15, 2006
    Crystal Spring, PA
    Doesn't matter what time zone your log department is in. You are to use the time zone your company is headquartered in.
  7. LeadfootSlider
    170
    39
    Jul 15, 2006
    Crystal Spring, PA
    ....for further confirmation on this issue refer to the FMCSR 395.8 (i). It reads in part "The driver's duty status record shall be prepared, maintained, and submitted using the time standard in effect at the driver's home terminal..."
    Several DOT officers in different states have affirmed to me that "home terminal" is to mean where your company is headquartered at.
  8. panhandlepat
    panhandlepat Road Train Member
    3,255
    2,243
    Jan 12, 2007
    luckily my home terminal AKA company HQ is in the central time zone, same as i live in. i keep my truck clock set to central and use it to log. my cell phone however changes to whatever timezone im in. i use it to keep up with the right pickup/delivery times. seems to work well so far
  9. LogsRus
    2,589
    358
    Nov 23, 2006
    Yeah having the same time zone usually helps allot! The cell phones are great for the local time deliveries etc.
    Have a great day
  10. MGASSEL
    MGASSEL Road Train Member
    1,301
    211
    Mar 27, 2007
    Co
    I was told to log my home time zone. WTF
    I will have to check with my company once I start with them on what they want.
  11. LogsRus
    2,589
    358
    Nov 23, 2006
    Yeah make sure you talk with them! Maybe they knew your state and the time zones are the same so to make it simple they just told you to log your home time. Possible i guess, I never look at the drivers state where they live since half the time it is never right in the computer.
    Let me know what they say
