What Temp should the drive axles be at?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Cat nip, Sep 8, 2010.
  1. Cat nip
    Cat nip Light Load Member
    192
    10
    Jan 17, 2010
    Magnolia, TX
    What Temp should the drive axles be at? My front Axle keeps riding at about 220, and the rear is around 160. Just to throw it in there tranny is about 190, until a climb...
  3. Krooser
    Krooser Road Train Member
    2,493
    1,066
    Jul 25, 2010
    Wisconsin
    I dunno... I need to replace the sending units on my pumpkins...
    I DO use an infrared thermometer on my hubs when I do a walk around every time I stop... especially in the summer when I have on a big load. Kinda cool to see what those hubs are doing...
  4. lego1970
    lego1970 Medium Load Member
    504
    165
    Oct 10, 2008
    Blue Springs, Missouri
    My front one runs hotter. This is sad, but to be honest, I can't remember what the actual numbers are because I normally just scan the guages to make sure no needle is out of whack, besides half the time the guages never work. I know they never go over the halfway point on the guage even running over 90k in the ozarks. The long grades out west might be different, but again I never remember my last truck going past the halfway point when I used to run out west but I do remember it's front axle ran hotter as well. I'm laid off for another week or so, but I'll check the actual numbers next time run if nobody else chimes in.
  5. rbht
    rbht Heavy Load Member
    888
    525
    Jan 23, 2010
    CT,NH
    on a warm day my front will run around 200 and the rear around 150, if you get around 250 i would start to worry.
    TheFriscoKid Thanks this.
  6. Krooser
    2,493
    1,066
    Jul 25, 2010
    Wisconsin
    Synthetic gear oils are good to about 280F before you have to start worrying... mineral oil start to break down at 225F or so...
    Years ago we used to have to hole up at a truck stop in the daytime during the summer before we could pull Baker grade headed west to California. 20 miles uphill in 110F heat wouldn't cut it before we had lube pumps in the rears and syn. oils.
    The truck stop bunk houses used to be full of guys with daycabs ( and sleepers) waiting out the summer heat.
  7. northstar73
    northstar73 Bobtail Member
    Sep 9, 2010
    Denver, CO
    I believe the front pumkin runs hotter because there's a lot of torque transfer going on in there, since the power divider is splitting the torque between the driver axles. I remember my trucks always ran the front driver hotter. Never had a failure, tho. I was a company driver and the truck I was assigned to got great maintenance.
    heyns57 Thanks this.
  8. Gonzo_
    Gonzo_ Medium Load Member
    307
    143
    Oct 30, 2008
    Clayton, NC
    All of mine: Tranny, front & rear diffs all run right around 190 in cool weather but in hot 100 deegree plus desert type regions it will climb up to 220 (max)..
    Just a FYI: if your guages don't work, it is a good idea to get them working.. If you have a wheel seal go bad and you loose oil, the first thing you might notice is the temp getting hotter... The rearend you save just might be your own either O/O or company driver!!
    I have full synthetic in everything.. (I don't know anyone who runs old mineral based oil any more with the huge improvement synthetic offers)!
  9. groundpounder
    groundpounder Road Train Member
    2,569
    1,039
    Nov 13, 2009
    Most of the 379's I've either owned or driven over the years in the summer the main trans usually just under 200 unless I'm out west pulling mountains, front drive between 180-190, and rear drive a little less than the front...
  10. rjones56
    rjones56 Heavy Load Member
    823
    486
    Jul 15, 2008
    staunton va
    My rear temps usually run about 100 degrees hotter than the temperature outside.If your fluid level is low,they would be higher.Any kind of mechanical issue would show higher temps as well.
  11. HEAVY DUDE
    HEAVY DUDE Road Train Member
    1,388
    555
    Jan 5, 2010
    NUNYA
    On a hot day, loaded heavy, my temps are about the same as yours. I don't think you have much to worry about.
