What style of aftercooler for small cam Cummins
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mile marker 27, Aug 1, 2022.
  1. mile marker 27
    mile marker 27 Road Train Member
    1,229
    1,633
    Dec 4, 2019
    4D314D0A-8EE1-4AA9-A913-E3835F0FF13B.jpeg 7FAF4BC7-E7D1-4A13-A5BC-FA567F110DE8.jpeg Well it appears there two styles of aftercoolers that bolted to the heads of a small cam engine. I’m adding an aftercooler, pulse manifold, turbo and crossover pipe, to this soon to be 160 CPL engine. I’ve got access to either style of aftercooler. Here’s a pic of each style. Which should I go with? From my experience the, “tin top“ style cooler was on nearly all Big Cams until series 4, low flows.
    OLDSKOOLERnWV Thanks this.
  3. Rideandrepair
    17,219
    55,894
    Aug 8, 2015
  4. pup
    pup Light Load Member
    252
    256
    Dec 3, 2011
    n.h.
    The tin one is the better choice. Much easier to service if you do need to take it apart & reseal it. Which may not be a bad idea anyways.
    The tin cross over pipe to the turbo can split open underneath so for that the aluminium one is the one to have.
  5. mile marker 27
    1,229
    1,633
    Dec 4, 2019
    Speaking of, “cross over pipe”, there several different choices. Some are angle towards the front of the engine, some are slightly angled and some are straight across. Some tubes come out of the side of the aftercooler(solid aluminum style) instead of the top and this doesn’t allow for the use of Jakes.
    Rideandrepair Thanks this.
  6. Inderjit
    Inderjit Heavy Load Member
    716
    703
    Sep 17, 2017
    If you can find one off an NTC-475 go with that!
    Rideandrepair and mile marker 27 Thank this.
  7. mile marker 27
    1,229
    1,633
    Dec 4, 2019
    I’m very limited on the amount small cams and big cams, for parts around here and not even sure I’ve ever seen a NTC 475. I’ve been getting some accessories from a local sawmiller, who’s got about 15 Cummins engine for parts.
  8. Bean Jr.
    Bean Jr. Road Train Member
    5,468
    9,700
    Mar 30, 2014
    Could you do air-to-air? @Ruthless did ata using a manifold off a N14.
  9. Dino soar
    Dino soar Road Train Member
    4,789
    26,858
    Dec 8, 2017
    Air to air can be done, but the idea of the after cooler is that it sends warm air heated by the coolant into the cylinder to keep the cylinder temperatures higher at idle. It is easier and quicker for the truck to warm up and the cylinder temperatures will stay higher longer.
    The n 14 intake could be done but you lose that aspect of the after cooler. If the engine is highly modified it may help to keep egts down but most of the reports that I've read are that the after cooler works just about as well and the benefits of it outweigh using the air to air.
    Coffey, spsauerland and OLDSKOOLERnWV Thank this.
  10. Bean Jr.
    5,468
    9,700
    Mar 30, 2014
    So why do they do ata instead, and why was a 3406b ata 425, but aftercooled it was only a 400?
    Coffey Thanks this.
  11. Ruthless
    Ruthless Road Train Member
    8,802
    86,199
    Aug 28, 2010
    The City.
    Not me-
    Might could be @OLDSKOOLERnWV he knows mechanical cummins
    Bean Jr., Coffey and OLDSKOOLERnWV Thank this.
