what size lug nuts?
Discussion in 'Freightliner Forum' started by myrt, Aug 8, 2014.
  1. myrt
    myrt Bobtail Member
    5
    Sumrall, MS
    What size are the lug nuts on a 2000 freightliner fld? Which direction to they turn on the right front steer tire? I have tried 1 1/4" socket, 1 1/2", and 1 3/8" and none of them fit. Thanks!
  3. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Try metric- somewhere between20-22mm
  4. boneebone
    boneebone Road Train Member
    2,294
    2,365
    Mar 13, 2009
    They are 33mm, Right Hand Thread.
    bullhaulerswife Thanks this.
  5. Jaguar115
    Jaguar115 Heavy Load Member
    779
    745
    Apr 4, 2008
    Warsaw, Mo
    Righty tighty..lefty loosey.. And hire a service truck if you can't figure that out
    nshore harleyguy Thanks this.
  6. bullhaulerswife
    bullhaulerswife Forum Leader/Admin Staff Member Administrator
    28,227
    44,143
    Jul 23, 2007
    Midwest
    LOL Hubby said he things they are 32, so we have to be in the ball park here.
  7. myrt
    myrt Bobtail Member
    5
    Sumrall, MS
    Thanks for the help! I will try to get it figured out in the morning. Have to get it changed before the tire store closes at 12 because I have a run to make early Monday morning.
  8. Meskie
    Meskie Bobtail Member
    13
    7
    Apr 8, 2009
    Saskatoon Saskatchewan
    I always use 1 5/16 socket on mine.
  9. glockwise
    glockwise Light Load Member
    253
    225
    Apr 24, 2014
    X's 2 ^^^^^^
    actually X's 10 or 100 if you want to do them all...
  10. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,143
    Apr 1, 2011
    Broomfield, CO
    Try a 33mm or 1-5/16". Clockwise to tighten, counterclockwise to loosen. Recommend you use a 1" impact... anything else, you want to verify with a torque wrench, and you're looking for at least 450 ft/lbs.
    A lot of trucks use the same size socket for the nuts on the tie rods, as well.
