What makes more money in Flatbeds
Discussion in 'Ask An Owner Operator' started by pavel94, Feb 12, 2012.
  1. pavel94
    pavel94 Light Load Member
    164
    21
    Nov 22, 2010
    Waterford MI
    i am thinking of getting a flat bed and need help. First what type should i look for? And then what makes more money in flatbeds long hauls or short haul around 100miles to 500 or 500-1300miles or 1300+.
  3. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,114
    May 19, 2011
    Typically the short hauls will pay more per mile. What type should you look for? Are you asking should I get a regular flatbed, a stepdeck, an rgn?
  4. pavel94
    164
    21
    Nov 22, 2010
    Waterford MI
    Well we are looking into flatbed at first just so drivers can get used to tarping and securing the loads, but what should the rate per mile be for around 500miles and what should it be for 2000+ miles?
  5. Oscar the KW
    12,246
    28,114
    May 19, 2011
    Rates depend on where the load originates from and where it is going. Are you going to have direct customers or go thru load boards?
  6. SHC
    SHC Spoiled Rotten Brat O/O
    8,484
    7,046
    Feb 26, 2011
    Westville, IN
    Being up here in the north (Indiana, Michigan) you should look into covered wagons. That is what makes money up here where we are. Tarping and such is no big deal with one of them, and as you know, coils and plate steel are what gets the money in our area.
    If you are looking to sending your guys over a 500 mile radius tho, I'd suggest a 51' stepdeck, steel frame (coil package) with wood floor. This will open your ability to haul heavy machinery, coils, plate, tractors and many other things. Plus i like the lower loading height for stability of the load and ease of tarping and securement. You won't usually need a ladder and you can haul a much wider variety of things. But make sure you get a 50-51' so you can load 48' flatbed loads most the time. If you get a 48' step you will be limited on a smaller lower deck loading area.
  7. pavel94
    164
    21
    Nov 22, 2010
    Waterford MI
    Thank you so much SHC. How does the frieght out of eastern Michigan pay going out West WY,WA,OR,ID,UT? per mile bases or line haul. I called a few brokers and it seem like the frieght isnt much better then van for those going out west. And how much does the lease on a flat, step deck cost per week, just so I can do a few calculation.
  8. Cummins_444
    Cummins_444 Medium Load Member
    605
    1,014
    Apr 28, 2008
    Northwest, IN
    Stay in the Midwest, you should do pretty good finding decent rates. What ever you decide to run flatbed or step deck, get a unit that will allow at least 48,000 worth of payload. I will have to disagree with SCH on the steel frame wood deck 51 foot step deck idea. You will weigh to much for most steel loads. A coil package is extra cross members which is a must for coils. Aluminum trailers are stronger and lighter and will allow for heavier load capacity. You can get Aluminum 53ft step decks with full coil packages that weigh around 10,300 pounds.
  9. Allow Me.
    10,642
    12,108
    May 28, 2009
    Rancho Mirage, Ca.
    Also, take into consideration length of miles for "short" loads. What I mean is, if you get a 400 mile run, and loading/unloading times are normal business hours, getting unloaded at 7am, then deadheading 100 miles and not re-loading until 3pm might make you late for a 6am unload the following day, so your "shorty" actually turns into 2 days.
    TURKER Thanks this.
  10. Krooser
    Krooser Road Train Member
    2,493
    1,066
    Jul 25, 2010
    Wisconsin
    Stay out of the mountain west and west coast... cheap or non-existant eastbound freight.
  11. Prairie Boy
    Prairie Boy Road Train Member
    3,258
    1,913
    Nov 18, 2010
    Edmonton, AB
    Get a 53 foot tridem step deck and open the doors to cross border freight also.
