Im installing an OPS ecopure on my Freghtshaker Columbia with an s60 Detroit in it. I need a fully synthetic oil, but which one and which weight? I just bought the truck 15,000 ago, so im not sure what weight oil is in it. Since I might not need to change it again for 100,000+ miles, i need an oil that is synthetic and will work year round.
Any brands and weight recommendation? Should I go with what the book says on weght?
What kind of Oil?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Richter, Sep 8, 2013.
Mobil sells a good synthetic, so does Amsoil. 5W40 is the standard for synthetic diesel oil.
15w40 is the standard use for diesels during summer months, 10w30 when it gets cold. Cranking over molasses in the winter is never good. For synthetics as freightlinerman said 5w40 is what the standard is. You are correct 5w40 will be thinner when hot than 10w30 but will be thicker when cold. If you are going to run a full synthetic I would recommend mobile over anything. I have never been a huge fan of amsoil for the same price I can buy mobile. I don't think rotella makes a full synthetic and I wouldn't waste the money on that crap anyway. I have always had problems with rotella foaming. My pickup runs 30lbs at cruise and it foams up not impressed. Never have had a problem with mobile foaming.
A heavier oil will increased your oil pressure. And with a thinner oil you WILL find oil leaks. We have run heavier weight oils in vehicles before to solve oil leaking issues. Keep that in mind. I would contact Detroit and make sure you can get by with a 5w40 oil and that clearances and what not will not be effected. Also ask about changing oils given the milage. I have seen what happens when a car yes I'm using a car as an example has been run for 150k with conventional 10w30 and then has been switched to royal purple which is a full synthetic. Was not pretty if they'd been running it from the get go it would've been fine however after running a conventional and switching to a synthetic it doesn't work well. In 30k we ended up tearing the motor down. -
I politely disagree with 379exhd. You do have it backwards. 10w is thicker than 5w. 10w is usually used as an all-around (all-season) oil. But if you tend to run in colder climes, 5w would suit better. This is from 2 yrs as a mechanic in the Army and 2 college courses.
That all said, we are talking about multi-viscosity oils, hence the xxw30 or w40. As you can see, the 10w30 you mentioned has a more narrow range than the 5w40 freightlinerman suggested. I have always liked 5w40 in my personal vehicles for it's greater range. Stays thinner in the cold so it will continue to lubricate, but thick enuf in the heat so it doesn't just melt away (and continues to lubricate.)
I have only trucked for a yr, and that, as a company man. So I use what they give me, which is usually in a recycled bottle, meaning I have no idea what the brand or weight of the oil contained inside actually is. I was taught that oil pressure anywhere from 20 to 60 psi in my truck is satisfactory. So I like to see it right up the middle, where yours appears to be. On blistering days in the desert SW, I've seen it hovering right at 20. On frozen northern MI morning startups, it will almost reach 100.
My final comment...
I don't care if I'm using my fairy Godmother's own special oil with a magic machine that removes every last contaminant including those NOT known to mankind. I would not leave engine oil in a truck for 100k miles. Your opinion may vary.truckon Thanks this. -
I'm did not go to school to become a parts changer, didn't need to pay for it learned it in a garage over the years. I have seen what happens when using the wrong oils. Spent 10 hours stripping down a 350 that was dropped in a racecar because they ran 0w10 in it. Sure enough she ran...but not for long. Oil was 2 thin and we ended up with metal on metal contact. When I pull a dipstick and see metal shavings in the oil after less than one night you know there's something wrong. Loaded it on the trailer and headed home. Tore her down and was not impressed. I still to this day blame the oil after a rebuilt royal purple 10-30 went in her and she's ran fine ever since. Never been apart, no shavings, and she's won a few times. This is also why I do not trust or like rotellla that most people seem to swear by. I have seen it foam, in both my cummins and my CAT. I've never seen foaming from mobile unless it has been overfilled, that is not the oil that's the operator many people don't realize what overfilling a motor with oil will do.
As for bypass filters all depends on the filter. Have you ever seen a motor with a gulfcoast on it after 425K and no oil change? I have, they do work, I would trust them. somebody else was the guine pig there not me. I trust it. I would feel fully confident running 500k+ on an oil change with a gulfcoast filter. Other filters eh I don't know gulfcoast has the reputation, I've spoken with Jerry personally he knows what he's talking about, sometimes I think he knows more about what to do than caterpillar as much as I hate to say it. It truely is amazing what a good quality bypass filter will do. I've seen compairible motors and they're gummed up, not with the bypass filter. -
Or, you could just follow the OEM's recommendations and probably never have an issue due to experimenting with your engine. Only you can make this decision.
Just remember, a new motor will cost some money. -
As far as brands go, I personally think the Mobil Delvac line is the best one going for class 8 truck motors. The regular old Delvac that you can buy at Walmart for like $10 a gallon is really, really a good oil....
You could probably use that oil, change at 30k intervals per the OEM schedule, use a pair of quality full flow filters, like the Donaldson's and go 1.5 million miles no problem...
The bypass setup won't reduce the wear rates significantly, I don't believe, but they will allow you to extend the change interval. The way to think of it is economically, will bypass, synth oil, and extended drains save me money over regular mineral oil and traditional truck maintenance approaches?
Will I gain MPG with a synthetic? (yes, about one to two tenths of a MPG)
Do I get improved pump-ability and cold start ease in the wintertime with synth oil? (yes)
Do the additional costs merit the change over to synthetic?
Is there something else, (semi synth blends), that could be a better option?
It's a lot to think about, that's for sure.
I don't know if I helped, but my intention is to help.
Congratulations on purchasing your new baby, I know you want to maintain it with the best of everything..... I can relate. -
I'm coming from the world of diesel pickups so take this fwiw.
The biggest reason I run synthetic is for cold starts. Yeah, lots of motors get good long life in MN winters just by plugging them in overnight, but I like NOT hearing that awful "diesel rattle" in sub zero temps.
I have run Amsoil 15w-40 (yeah it's synth), Amsoil 5w-40, Mobil 1 5w-40, Shafers 9000 full synth 5w-40 (not the blend crap), and maybe a change or two of Rotella. Everything except the Rotella was sampled and none had any real advantage over the others. Never did any kind of scientific study, just that nothing stood out good or bad. Although the one time I put 16K on Amsoil 5w-30 the analysis said it could have gone further. 16K in a pickup was long enough for me.
In a situation where something goes wrong and your engine gets hot REALLY quick, you should get a little more protection using synthetic. The higher coking(?) point keeps the oil as oil to a higher temp. Could save an engine. Pretty slim odds that a situation like that occurs, but if it does, you have a little better chance of just needing to change oil instead of changing engines.
A ranking of the synths I've used based on nothing more than personal preference
Shafers 9000---A good oil that doesn't cost near what amsoil or mobil do. In 55gal barrel it's give or take $20/gal. compared to $35-$40. Yes the 9000 is FULL synth, not a blend. If not for the price factor, I'd be running Amsoil or Mobil.
Amsoil---in a little cold test we did here with ams, mobil synth and conventional, and rotella, the Ams ran off the stick the best at -10*F. The mobil synth was almost as thick as the conventional. Didn't have shafers at the time.
Mobil---Never had any bad experience with it, it's just really expensive and shows no benefit over the others.
Rotella---Too cheap. Not sure it's really a FULL synth.
Blends are a complete and total waste of money. Everything I've heard tells me they're all right around 10% synth, 90% dino. And...you can make your own if you want to. No reason you can't blend synth and dino when you change.
If long life is what you're after, just taking the time to read my babblings tells me you care enough about your engine that you're most likely gonna get a good long life outtta her regardless of what oil you use.trees Thanks this. -
I have grown partial to Schaeffer brand of oils. http://www.schaefferoil.com
I can get the Series 9000 5w40 full synthetic (a group III and group IV combination) for less than $20 a gallon, delivered free to me, and free oil sample kits included. I just priced a drum yesterday..... $1080 for a 55 drum, 3% off special, and free deliver to me or my dealer will have it shipped to him and he will bring it to me.... free. Even Wally World can't top that deal. And Schaeffer has been making great lube products longer than any other oil company in America... since 1839. Mobil, Shell, everyone else joined the party later.
The Schaeffer 7000, a synthetic blend 15w40 is $130 a drum cheaper than the 9000 series. Same free delivery. The 7000 has 25% PAO synthetic with group II+ conventional.
