What kind of lubricant can I use on the 7 pin electrical plug?
Discussion in 'Questions From New Drivers' started by TawcoTruck, Apr 4, 2023.
  1. TawcoTruck
    TawcoTruck Light Load Member
    155
    224
    Dec 11, 2022
    The truck I was issued is a pain in the ### to get in and out of the trailer. It needs to be cleaned and some kind of lubricant.
    KB3MMX Thanks this.
  3. bad-luck
    bad-luck Road Train Member
    3,242
    5,937
    Nov 16, 2013
    Baltimore, Maryland
    dielectric grease
    seagreg, flood, KB3MMX and 14 others Thank this.
  4. tarmadilo
    tarmadilo Road Train Member
    1,590
    4,246
    Dec 12, 2018
  5. Rideandrepair
    17,197
    55,775
    Aug 8, 2015
    Dip it in the fuel tank, slap the cleanest looking grease off the fifth wheel you can find on it. Done. Till you can buy some dielectric grease. Use it on the plug, anytime you change a bulb. When it’s not available, any grease is better than nothing,
  6. blairandgretchen
    13,212
    70,198
    Dec 9, 2011
    South west Missouri
    I love your "get her done" solutions.
    But yeah - brake cleaner, contact cleaner, followed with dielectric grease.
    I guess diesel would probably clean the crud out in a pinch.
  7. kemosabi49
    10,435
    44,376
    Jan 13, 2013
    SW Arkansas
    I've used WD40 to clean, followed by a dab of dielectric grease in each hole of the 7 pin on pigtail. Work it in and out a couple times and be good to go.
    indy89, TawcoTruck, bzinger and 2 others Thank this.
  8. JoeyJunk
    JoeyJunk Road Train Member
    8,763
    68,024
    Dec 31, 2010
    Washington, PA
    Whatever you keep on the shelf next to your bed.
    Thank you folks, Goodnight!!!
    TawcoTruck, bzinger and wichris Thank this.
  9. PaulMinternational
    PaulMinternational Road Train Member
    1,107
    5,472
    Aug 23, 2022
    I knew it was coming! :)
    TawcoTruck and JoeyJunk Thank this.
  10. JoeyJunk
    8,763
    68,024
    Dec 31, 2010
    Washington, PA
    I was surprised I was the first.
    TawcoTruck and PaulMinternational Thank this.
  11. skallagrime
    skallagrime Road Train Member
    3,836
    9,877
    Apr 10, 2012
    Indiana
    Thats what she said... and was dissappointed
