What is your favorite CB make and model?
Discussion in 'Experienced Truckers' Advice' started by BillyBobFrank, Oct 27, 2023.
  1. BillyBobFrank
    BillyBobFrank Light Load Member
    208
    388
    Nov 7, 2022
    I had a cheap model cb (under $100) in which I couldn't understand what people were saying, so I got rid of it. With winter here, I need to get a new CB and wanted everyone's input. Also, I'm trying to be frugal instead of cheap this time around, so I don't mind spending $100-$150 for a good quality CB, more if necessary to get good sound quality.
    singlescrewshaker Thanks this.
  3. tscottme
    tscottme Road Train Member
    I had 3 different. Cobra 29 ltd, uniden pc68 or 66, bearcat 880. All cost about $100-120. The first two were the same radio made by 2 different companies. Uniden 880 fit in the pre-cut hole for a CB in 2021 KW T680. Add external speaker.
    BillyBobFrank and Dennixx Thank this.
  4. 201
    201 Road Train Member
    12,047
    24,583
    Apr 16, 2014
    high plains colorado
    "Get yourself a Midland", was the cry, but Cobra dominated the CB market.
    BillyBobFrank Thanks this.
  5. kemosabi49
    10,435
    44,381
    Jan 13, 2013
    SW Arkansas
    Most any radio will do right out of the box. The key to good performance is your antenna system. Check out some of the threads here on TTR in the CB forum. Some good info there about this.
  6. singlescrewshaker
    4,689
    40,504
    Dec 31, 2017
    Little Havana, FL
    I don't know a ton about cb's but having a good coax, ground, connections tight, & antenna (swr) tuned will probably help with receiving clarity..
    Previously had a $45 Uniden pro 510xl with two tunable tip, 3' firestick's that sounded great. Much better than the Cobra 29 I got now with a coax from the '90's & single "pre tuned" 2' Francis whip..
  7. Good Faith Trucker
    Good Faith Trucker Bobtail Member
    8
    19
    Oct 23, 2023
    Cobra Model 29 LX is the only one I’ve used, got the job done and had an easy to use, decent look that could change the back light color which was a cool feature. I will stick with the same one next time I go OTR (local driving now) and you can find them reman for 85 bucks. Would definitely recommend.
    peace
  8. flood
    flood Road Train Member
    4,157
    4,020
    Dec 25, 2010
    Any of the cobra 29's will get the job done.
    I have a cobra 29 "classic", upgraded to the 29 "nightwatch", upgraded to the 50th anniversary Ltd lx..
    Take it to a GOOD SHOP to have your antenna system checked..
    A 3 watt radio will work just fine with a good antenna setup.
    A 50 watt will work like crap with a bad antenna setup.
  9. abyliks
    abyliks Road Train Member
    3,746
    8,692
    May 2, 2010
    ludlow MA
    We have bearcats in most of the trucks that seem pretty good, good antenna and a good coax and I can hit the office scale or the loader operator and that’s all I care about
  10. RockinChair
    RockinChair Road Train Member
    4,918
    12,257
    Feb 19, 2012
    CC, TX
    In your budget, a Cobra 29 LTD Classic or a Uniden PC78LTX are your best bets. For best sound quality, get a good external speaker and a noise-cancelling mic. And as others have said, having a properly-tuned antenna and good coax will make a big difference in your transmit and receive range.
    Dennixx Thanks this.
  11. 201
    12,047
    24,583
    Apr 16, 2014
    You may laugh, but my 1st CB was a JC Penny, and I think it had Royce guts, and it got out great. I used that CB in many trucks and 4 wheelers.
