What is your Empty Weight? 53 Footer
Discussion in 'Refrigerated Trucking Forum' started by OhNoTerry, Nov 2, 2021.
  1. OhNoTerry
    OhNoTerry Medium Load Member
    309
    470
    May 22, 2021
    Please reply with your combined weight when empty as well as your make and model for your tractor and 53' reefer trailer set up. If you know your tractor and trailer weights individually please write that as well. *Scale weight please, no door or stamp weights*
    I'm about to order a new truck that sits at 18,900 lbs 1/4 tank fuel on the spec sheet and would like to know how much I'm ruining my marketability running with this set up. Some are saying I'm not too far off from how much aero truck and trailers weigh, but I'd like to see some numbers. I plan to run a 53' SS Great Dane/ TK unit set up.
    Rideandrepair Thanks this.
  3. Crude Truckin'
    Crude Truckin' Alien Spacecraft
    2,377
    6,498
    Oct 22, 2016
    North Dakota, Eh?
    By the spec sheet? Or on a scale? Stamped weights are never correct. Fill with fuel and weight it with you and all your stuff in it.
  4. OhNoTerry
    309
    470
    May 22, 2021
    For the replies a scale weight. From my spec sheet I've been told it's total weight with 1/4 tank fuel. I have awhile before this truck hits the production line so I'm trying to tweak some things before it's too late.
  5. Crude Truckin'
    2,377
    6,498
    Oct 22, 2016
    North Dakota, Eh?
  6. OhNoTerry
    309
    470
    May 22, 2021
    KW W9L
    Rideandrepair and Crude Truckin' Thank this.
  7. Crude Truckin'
    2,377
    6,498
    Oct 22, 2016
    North Dakota, Eh?
    Ya I'd be willing to bet you'll be north of 20k fueled and all equipment on it. My 2018 Cascadia is 21k with wet kit, tire chains, my sheet, 280 gallons of fuel, def, etc.
  8. Six9GS
    Six9GS Road Train Member
    1,473
    3,695
    Dec 3, 2012
    Yuma, AZ
    2019 Volvo VNL760, All tanks full. Empty weight around 34,500 lbs. I change trailers regularly and some of our reefers are heavier than others. I don't have scale ticket with individual weights handy.
    Hope that may help.
  9. Rideandrepair
    17,198
    55,776
    Aug 8, 2015
    2000 Classic, 285wb, 84” bunk, full tanks. Lots of tools onboard weighs in @20k. Trailmobile 53’ paper spec dry van trailer is heavy @15k. Scales 45k with half tanks.
    OhNoTerry and Crude Truckin' Thank this.
  10. goga
    goga Heavy Load Member
    894
    1,586
    Nov 11, 2021
    Earth..
    06 Century mid roof, 08 Utility reefer, full tanks, my ~500bls chains and stuff, ~35k.
    Rideandrepair and OhNoTerry Thank this.
  11. Scoot 1971
    Scoot 1971 Light Load Member
    265
    348
    Nov 22, 2018
    17' Cascadia condo sleeper with Dd15, your basic mega carrier longhaul truck. My truck is right at 19500 lbs with dual 100 gallon tanks at about half full. With an empty 53' reefer weight is around 34500 lbs. These are Utility brand trailers with Carrier reefer units. So 15000 lbs for the trailer.
    OhNoTerry Thanks this.
