What is this Rattle in the front of my Cat engine?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Cam Roberts, Jun 20, 2018.
  1. Cam Roberts
    Cam Roberts Road Train Member
    1,621
    1,938
    May 13, 2018
    IT is a Cat c12. Cat did a complete rebuild 250k miles ago. I have had the truck for a year and its always had this rattle. I have heard one or 2 other trucks with cat motors on site with the same rattle. My mechanic who owns a large fleet, half of which are cat engine equipped told me it will probably make that noise for the rest of its life its just wear. Anyhow, I have OCD and it bugs the crap out of me.
    The ratte sounds like a bad tensioner but its not that. I removed the belt and ran the truck. Only thing spinning was the crank pulley and balancer, Still makes the sound. Seems to be coming from the crank area. It is definitely coming from the front of the motor and not the radiator. Noise is too low on motor to be coming from the idler gear but who knows. ONLY makes the sound on a warmed up engine and the sound goes away if you bump the rpms up. No noise when cold so I find it hard to believe its the balancer.
    Heres video. The first part is with the noise on a warm engine. second part of video is a cold engine and no noise. Your thoughts?
  3. bzinger
    bzinger Road Train Member
    16,596
    65,751
    Dec 10, 2014
    omaha , ne
    Turn the stereo up louder cam lol
    mpd240 and Roberts450 Thank this.
  4. Cam Roberts
    1,621
    1,938
    May 13, 2018
    cant hear it in the cab my friend. just if I get out and walk in front of my truck. I have the most INSANE OCD you could possibly imagine. I guess I should post this thread on OCD forums lol
    bigguns and bzinger Thank this.
  5. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,541
    May 22, 2017
    The problem is it's a c12. Get rid of it. I'm not kidding. They are money pits.
  6. rbrtwbstr
    rbrtwbstr Road Train Member
    3,331
    7,589
    Jul 11, 2012
    in the bush somewhere
    Just a thought, when it was rebuilt, did you replace the crankshaft dampner? Although I've never seen or heard of one making such noise, I guess it would be possible.
    One truck I drove had a fresh Cat platinum rebuild just before I got in it. That engine had a whine to it at idle that was very hard on the ears. I never did figure it out. It still runs, and still whines.
  7. Oldironfan
    5,777
    5,541
    May 22, 2017
    Is the video at low idle? Does it go away at high idle? Could be a loose mount, or something possibly.
    N14 engine rattle at low idle also.
  8. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    First place I would be going is checking gear lash setup on the front gear train. Do you know for certain it was set to specs during In-frame? Have you removed belts to confirm it's not anything accessory?
    bigguns and jamespmack Thank this.
  9. Cam Roberts
    1,621
    1,938
    May 13, 2018
    It’s probably gear lash. Although it does not do it on a cold engine. I removed the belts. Still there. A very large and reputable cat dealer locally did the complete overhaul. I assume they did everything to spec. It was 250k miles ago and done about 8 years ago.
    C12 an ok motor for local work bro. Have a few friends running them. Mine is tuned to over 500hp. She pulls with the big boys.
    I’m pretty sure the dampener is original. Like you, I’m scratching my head if that could make the noise but you would think it would make the noise hot or cold. There is no play in it
    Yes that’s low idle. Nothing is loose bro. I had motor mounts tightened. Everything is solid. Sounds just like a tensioner rattle
    Oldironfan and bzinger Thank this.
  10. Cam Roberts
    1,621
    1,938
    May 13, 2018
