I'm looking into a trucking company that has both a bunk heater and an APU unit.
I did OTR before and I had an APU Tripac. It was this one and on page 6 of that link you can see the control panel, that's what I had and used to control either the heat or the AC.
https://www.thermoking.com/content/.../products/55719_TriPac_Evolution_Brochure.pdf
So my question is, is the bunk heater a separate unit from the APU?
Or is the bunk heater just the heat that comes from the APU unit and they call it a "bunk heater" instead of just a "heater"?
If the APU unit has both AC and heating then what is the purpose of having a bunk heater if the bunk heater is a separate unit from the APU?
Can somebody explain this to me.
What is the purpose of having BOTH a bunk heater and an APU?
Discussion in 'Questions From New Drivers' started by BeHereNow97, Aug 30, 2021.
Page 1 of 3
lovesthedrive Thanks this.
The reason is efficiency, in VERY cold, the apu will idle up to keep batteries fresh and engine warm,
The bunk heat is integrated with the ac ducting for warmth but the electric current draw for fan and ignition element on the heater would be too great over a long period of time, if running the apu and using the coolant for a heater core, it will also not be quite warm enough to keep the cab quite warm enough even as it raises engine temp enough to keep it from freezing in extreme temperatures.beastr123, tscottme, Flat Earth Trucker and 2 others Thank this. -
The bunk heater is a enclosed space heater that has a higher efficienct rating over an apu. Tho it will in time draw down the batteries. Not all companies will supply you with an APU. Tho they will supply you a bunk heater.
APU's keep you comfortable in the heat and use a pint per hour of fuel. Where if you have to idle your truck you will guzzle 1 gallon per hour to keep your sleeping area cool in the summer.
Bunk heaters are about $50-$100
APU are around $800-$2000Trucker61016, stacks and Flat Earth Trucker Thank this. -
Are you talking about a webasto bunk heater along with an apu?
Trucker61016 Thanks this. -
beastr123, CorsairFanboy, mitrucker and 2 others Thank this.
Some APU’S use a bunker for heat . If it’s a separate bunk heater it’s great for a quiet sleep in moderate temperatures and is cheaper to run than a APU plus it saves on APU hours which lowers APU maintenance.
w9l Thanks this. -
A bunk heater is part of the APU.
Trucker61016, tscottme and Flat Earth Trucker Thank this.
Page 1 of 3
