What is the Payload Weight Limit of My Truck ?
Discussion in 'Questions From New Drivers' started by SilverBulletBand, May 13, 2020.
  1. SilverBulletBand
    SilverBulletBand Light Load Member
    288
    230
    Dec 15, 2018
    Wetumpka, Alabama
    I'm a newer CDL-A holder and this is a good question and learning experience for other CDL Newbs as well. That's why I posted this in this forum. CDL schools don't really cover this topic thoroughly.
    I drive a 2016 Freightliner M2 106 Single Axle with a 27 foot flatbed on it.
    Door tag shows 33,000 GVW.
    I need to know the Payload Weight Limit on it.
    I'm not sure what the bed or chassis only weighs. I'm guessing maybe 3000 on the bed and 8000 on the Chassis. I'm going to get it weighed as soon as I can... empty.
    33000 - 11000 = 22,000 lbs is my best guess.
    Finding the Chassis weight on Freightliner's website is useless. So was the salesman I talked to.
    Where can I find the weight of CHASSIS ONLY ?
    We also have a Tandem Axle I'd like to know the Payload Weight Limit on it as well. 52250 is the GVW on it.
  3. Dave_in_AZ
    369,972
    Should be a sticker in the door frame or glove box that has the dry weight as well.
    If you're going to scale it, make sure it's full of fuel.
  4. Eddiec
    Eddiec Road Train Member
    2,191
    3,358
    Feb 2, 2015
    Fuel your truck up. Take it to a Cat or any certified scale. Weigh it. Subtract your empty weight from your GVW weight, that's how much freight you can carry. Do the same for the tandem truck as well.
  5. SmallPackage
    5,273
    16,442
    Dec 20, 2019
    Marion Texas
    Had a 2003 steel cab FL 60 33,000 gvw with twin 50 gallon steel fuel tanks and 24’x96” aluminum( not Frb) wood lined dry van body and steel lift gate. Weighed around 14,000 empty.
    The M series I believe is an aluminum cab with aluminum tanks and with just a flat bed I’d guess around 10,000- 12,000.
    Best to take it too a certified scale and weigh like @Dave_in_AZ said with full fuel.
    The registration slip that is supposed to be carried in the truck should say it also, but It may also be a rough average guess if someone didn't register it to an actual weight ticket.
  6. singlescrewshaker
    4,689
    40,504
    Dec 31, 2017
    Little Havana, FL
    Like the other boys said, pull on scale empty & full of fuel & tools, & you..
    Also you might as well go off of 32,000lb GVWR. Guessing the truck has a 12,000 steer, & 21,000lb rated rear.? Really aren't supposed to exceed 20k back there..
  7. SilverBulletBand
    288
    230
    Dec 15, 2018
    Wetumpka, Alabama
    I've looked all over. No sticker that shows that.
    singlescrewshaker Thanks this.
  8. SilverBulletBand
    288
    230
    Dec 15, 2018
    Wetumpka, Alabama
    Yes, I believe that's what they're rated at.
  9. SilverBulletBand
    288
    230
    Dec 15, 2018
    Wetumpka, Alabama
    How much does it cost to weigh a truck at a CAT scale ?
  10. SmallPackage
    5,273
    16,442
    Dec 20, 2019
    Marion Texas
    Last time I used a Cat scale was June of last year and it was $11.50 at the Loves down the highway from my house.
  11. Powder Joints
    7,506
    7,414
    Sep 25, 2007
    Rosamond, SoCal
    Gross should go something like this, Steer Axle 12,000 (aprox) Drive Axle 20,000, now if you have a tandem on the trailer it will be at 34,000, so gross 66,000. Now go to the Cat Scale fill up on fuel and scale out, subtract the tare weight from the projected Gross and you will have your Net Load weight. 66,000 (Legal Gross)-28,000(Projected Tare) and you could load 38,000 on the trailer. The Tare and gross is projected you need to get a scale ticket to be dead on.
    SilverBulletBand Thanks this.
