What is the ideal set up for pulling a 48ft flatbed?
Discussion in 'Questions From New Drivers' started by F1Trucker, Apr 8, 2018.
  1. F1Trucker
    F1Trucker Bobtail Member
    6
    Apr 8, 2018
    I'm currently looking at purchasing a semi truck that will be used to pull a 48 foot flatbed. I've been thinking about a mid-roof Kenworth T660 with a 10 speed transmission and a 3.36 ratio. Would this truck be a good choice for this type of work? Would it be capable of doing tough jobs such as hauling 48,000lbs through West Virginia? Please let me know if this truck would be a good purchase or not. Also please recommend what truck brands, models, transmissions, ratios, etc. would be for best flatbed work.
  3. jsnell
    jsnell Light Load Member
    253
    343
    Apr 12, 2016
    Brands don't mean anything. Drivetrain is more important. Like 15L motor, 500 hp, 13 speed O.D. and more like 3.55 rears but even that is subjective.
    Lepton1 and TripleSix Thank this.
  4. Rooster1291979
    Rooster1291979 Road Train Member
    1,308
    1,751
    Sep 4, 2012
    NOLA
    Fleet trucks pull 48klbs through west Virginia everyday. 48k is 48k no matter if it's in a box or open deck.
    With a 48' flatbed you need to look at 5th wheel space from the cab. Some loads will have overhang front and rear. Will you put a rack on the truck? Open or enclosed? Enclosed will require more space between the plate and the cab.
    Will you be going to job sites off fire roads, logging trails or lots of mud? What kind of ground clearance do you need? Some trucks have very low bumpers, tanks and fairings. Will you rip those off?
    Are you looking into os/ow? What size axles are you looking for? Are you going to add a lift axle? Do you want to run tall rubber or low pro?
    There's far more important matters than brand. Personally I don't care who made the truck. I just need it spec'd right.
    Lepton1 and Truckermania Thank this.
  5. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    Gear ratio is a can of worms I like the 13 speed and 370 on low profile my two cents
    Lepton1 Thanks this.
  6. Long FLD
    Long FLD Road Train Member
    11,375
    45,878
    Mar 4, 2015
    Depends on what you plan to do with it. Many “off the lot” trucks won’t allow you much room to overhang the front of your trailer much. Will you carry your gear on your trailer or do you need room for a cabinet rack?
    No Time Thanks this.
  7. Pedigreed Bulldog
    7,737
    14,421
    May 7, 2011
    I've got 485 hp/1660 ft lbs, an 18 speed, 4.17 rears and tall 24.5's, and it seems to work great for me. Mostly 2-lanes, but it'll still get out there and run with the big dogs (tachs out @ GPS indicated 84.9 mph). 240" WB in a SFA daycab leaves plenty of room for overhang, tool boxes, and whatever else I need to carry. If I had a sleeper and drove more interstates, I probably wouldn't have such aggressive gearing in the rears...but for a day cab doing local/regional work it gets the job done.
    Truckermania and Lepton1 Thank this.
  8. Espressolane
    16,986
    102,426
    Purchasing a used truck is a compromise.
    The people who originally purchased the truck also compromised. The idea was to get equipment that could run the areas of operation for that company, then have some reasonable resale value.
    More basic information is needed to give you better answers.
    What type of freight do you plan to hauls the most, where will most of this driving be.
    If you do plan to run flatbed, mid roof is better than tall roof. Some mills can be very low clearance.
  9. Fatboy42
    Fatboy42 Light Load Member
    281
    389
    Feb 9, 2011
    Indiana
    I run old cabovers just got another one 1986 9670 350 big cam 9 speed with a 3 stage Jake everything works clean truck good rubber $5000.00 it does what I need I pull 48 foot spread with side kit and haul some permit loads I needed another truck because I am doing extensive work to my 1977 Pete 352 that I fave been running for several years. Guess my point is it my not be exactly what you want but if it will work and is cheep and reliable go with it.
    Brettj3876 Thanks this.
  10. Pedigreed Bulldog
    7,737
    14,421
    May 7, 2011
    Not necessarily. If you have time, you can look for a truck that has the specs you want. Only compromise I made with my truck was the wheel base. I had been looking for 200-215", but when this one came along with every spec spot on and only 260K on the odometer, I figured the extra 3' or so wouldn't be a problem...and it hasn't been.
    Important thing is to know what you NEED, as well as what you WANT. Salesmen will attempt to sell you what they HAVE, which will likely be neither what you want nor what you need. By knowing the difference between what you NEED vs what you WANT, you'll be able to decide whether or not to compromise to accept what a salesman might have. More time you have to look, the less compromising you'll need to do.
  11. TripleSix
    127,950
    Ina addition to Reverend Bulldog, watch out for the Bait and Switch, where they draw you in with the truck that you were looking for, spec'd the way you want. Suddenly, you fill out credit apps, get accepted, happier than a fat rat in a cheese factory, tell everyone about it, even catch wood, take time off work, tell the salesman what day you're coming, everything is fine and dandy, all the planets and stars have aligned....
    ...and two days before you show up, the salesman calls and tells you the truck is gone. But, I thought we had a deal? "Wait! I have another that just rolled in that I think you will like!"
    The frustrating thing about telling drivers about the Bait and Switch is, you can warn them until you're blue in the face, AND THEY STILL FALL FOR IT. Yes, I know you told everyone that you were getting a truck, yes I know you caught wood, yes, I know you took time off from work and even bought a plane ticket.
    Walk away. Make em pay for yanking you. And tell the next salesman your story. He will not do it.
    When you walk, you hurt their pockets. All that effort, answering all those questions, taking your phone calls on the first ring and listen to you talk about what you were going to do with the truck and pretending to be your friend. Thought for sure that you were a sucker. Planned a trip with the wife and told her to buy some pretty panties. Even caught wood.
    "But driver, I thought we had a deal?"
  12. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,056
    Nov 18, 2014
    Land of local
    Mp or a real mack? I know the xt file is something like 487hp and 1760 if I remember correctly
