What is the factory battery disconnect switch rated for?
Discussion in 'Freightliner Forum' started by rbrauns, May 5, 2020.
  1. rbrauns
    rbrauns Light Load Member
    164
    56
    Dec 7, 2014
    I have a 2008 Cascadia and the way my APU is wired, the factory installed battery disconnect switch does not cut power to the APU or the Themoking inverter.
    I want to have these things run through the battery disconnect switch but I don't know what the switch is rated for.
    Most aftermarket battery disconnect switches are rated around 200 amps with a 1000 amp peak for 10 seconds.
    Does anyone know what the factory switch is rated for?
