What is the difference between a 40,000lbs load, a 44k lb load, and a 46k? In MPG?
Discussion in 'Ask An Owner Operator' started by RoadRunner36, Jan 19, 2020.
  1. RoadRunner36
    RoadRunner36 Bobtail Member
    32
    13
    Dec 26, 2019
    Im trying to find some information on the differences in these upper end of the legal weight limits.
    It seems like there is some signifigant bell curve when measuring MPG based on load weight, that starts to dip sharply around 44000, and more sharply at 45,500...
    Considering my truck weighs 33,500 empty trailer and full tanks, and gets about 6.3 MPG overall. What kind of effects on my MPG could these varying weights have.
    Lets say
    40000
    41000
    42000
    43000
    44000
    45000
    46000
    Lets say flat roads mostly.
    Is there a curve? Does anyone know how to calculate the differences?
    Feel free to apply an est MPG on each weight, or create an answer that does not necessarily fill in the blanks. Im open to any answer that lights the way
  3. TallJoe
    TallJoe Road Train Member
    7,490
    16,271
    Apr 12, 2016
    Chicagoland
    Flat:
    40000 : 6.7
    41000 : 6.7
    42000: 6.6
    43000: 6:6
    44000 6.5
    45000 6.4
    46000 6.3
    hills
    40000 : 6.3
    41000 : 6.3
    42000: 6.2
    43000: 6:2
    44000 6.0
    45000 5.9
    46000 5.4
  4. Dale thompson
    5,100
    42,201
    Nov 20, 2013
    commerce twp,mi
    Given the minimum information I think TallJoe has a estimate that I would totally agree with.
  5. Milr72
    Milr72 Medium Load Member
    568
    1,381
    Dec 16, 2011
    S W Missouri
    The real question should be is how much more does the 46,000 pound load pay versus the 44,000 or the 40,000 pound load. The extra weight should pay a lot more than what the additional fuel cost would be.
    alds, Calregon and Coffey Thank this.
  6. snowwy
    snowwy Road Train Member
    20,525
    13,261
    Jul 6, 2009
    Too many variables to possibly have an answer.
    You can run the same load on the same route with the same weather conditions fueling up at the same station and have up to a 1 mpg difference.
    Fuel quality is never the same from day to day.
    And I've seen a 1 mile difference in the mountains.
    Crude Truckin' Thanks this.
  7. RStewart
    RStewart Road Train Member
    3,163
    5,024
    Aug 21, 2015
    Norman, OK
    With my truck there isn't much different between 40k and 44k on flat ground. In the hills it will be a little different but how big the hills are and how many they're are will determine tree difference. Worst case scenario, maybe half a mile per gallon. Driver has a big impact on this as well.
  8. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    You are going to burn more fuel to lift a heavier load over a mountain.
    However.
    You open a can of worms with that question. For example I had a older big cam pulling townhill near Breezewood at 80000 at 19 mph or so upgrade. Thats depending on temperature and humidity situation. If shes frisky she will run that at 21. It's 5 mile pull. It was a fuller 10 I believe and other standard late 87's era truck hardware.
    Not long after later that year company gave me a virgin mack day cab with a 350 and a significantly different set up. Fuel capacity was no where near as much and I did the same hill, same load with the same shipper at 45 mph. It did not take very long to lift that up and over. And more or less we managed to not need to carry so many gallons to get a days work in. Although refueling was possible if running 4th load on that flatbed for that workday.
    Most of my past 10 tractors or so, all of them were relatively modern. And did not "act loaded" until there was a certain amount in that trailer. For some of those tractors they LIKED to be loaded. Others with less than ideal engines (Particularly if employer relies on the smallest, least HP engines) they will drink gallons trying to run a hill. And some areas of the USA like western Kansas is one big upgrade from Kansas City towards Denver (A mile up) and fuel is out the window some days.
    I can go on. But as a rule of thumb for a 515+ detriot or similar for the 2000 era I expect a minimum of 1650 working miles before fueling. As a team we go through 10 gallons a hour and refuel every 30 hours give or take on average. That works out very close to what the tractor would be reporting to us around 6.8 loaded. Better than that empty. And we could some days trust it to get us 2100 miles if necessary. (And did once or twice, it's a gamble)
  9. PE_T
    PE_T Road Train Member
    Assumption:
    80k max gross weight
    7.0 mpg at 62 mph
    35k (empty weight with reefer trailer)
    9.5 mpg at 62 mph
    80k (gross) - 35k (empty) = 45k (max load weight with reefer trailer)
    Calculations:
    0k (empty) (0%)
    9.5 mpg at 62 mph
    11.25k (load weight on reefer trailer) (25% of max load weight)
    8.88 mpg
    22.5k (load weight) (50%)
    8.25 mpg
    33.75k (load weight) (75%)
    7.63 mpg
    45k (load weight) (100%)
    7.0 mpg
    sealevel and Midwest Trucker Thank this.
  10. Long FLD
    Long FLD Road Train Member
    11,344
    45,646
    Mar 4, 2015
    Unless you’re loading at the same place and going to the same place there are way too many variables to measure the difference between 6k of weight.
    stwik and D.Tibbitt Thank this.
  11. mpd240
    mpd240 Road Train Member
    1,540
    3,622
    Sep 17, 2011
    Minnesota
    Flatbed. Wind resistance seemed to make the greatest impact for me.
    Coffey Thanks this.
  12. PE_T
    Cost of load weight based on following assumptions:
    3,000 miles per week
    $2.75 per gallon (IFTA included)
    Calculations:
    0k (empty) (0%)
    9.5 mpg at 62 mph
    3,000 miles / 9.5 mpg = 315.79 gal
    315.79 X $2.75 fuel = $868.42 (weekly fuel)
    $868.42 X 45 weeks (1 year) = $39,079
    8.88 mpg
    3,000 miles / 8.8 mpg = 340.91 gal
    340.91 X $2.75 fuel = $937.50 (weekly fuel)
    $937.50 X 45 weeks (1 year) = $42,188
    8.25 mpg
    $45,297
    7.63 mpg
    $48,406
    7.0 mpg
    $51,515
    Midwest Trucker Thanks this.
