What is the atc button on the dash board?
Discussion in 'Questions From New Drivers' started by Newdriver85, Sep 22, 2013.
  1. Newdriver85
    Newdriver85 Light Load Member
    59
    24
    Mar 22, 2013
    Philadelphia pa
    Among all the switches on the dash board there is one that I have no idea what it does. The top part of it has a tire that looks like it's running over water and spitting water off the back side of it on the bottom of the button it says ATC. What does this switch do ?
    19d Thanks this.
  3. APCP
    APCP Bobtail Member
    16
    4
    Sep 20, 2013
    Auto traction control.
    CondoCruiser Thanks this.
  4. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    When it lights up your automatic power divider in engaged. A ABS sensor detected a tire slipping and activated the light.
  5. luvtotruck
    luvtotruck Road Train Member
    1,978
    1,161
    Jul 30, 2013
    Phoenix Arizona
    What they said!^^^^
  6. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,733
    Apr 18, 2010
    Tennessee
    It's a modern version of a limited slip differential. Under acceleration the ABS sensors detect one wheel spinning more than the other and it corrects the situation by lightly tapping the brakes to that wheel and if severe enough the ECM will cut the throttle back for a millisecond. Use it only in bad weather and wet roads. You should have an owners manual in your glove box. Read what the manufacturer says about it.
    For the Billy Bob truckers out there it stands for Air Traffic Control. Cleared for takeoff! :)
    chalupa Thanks this.
  7. claw444
    claw444 Bobtail Member
    49
    16
    Mar 20, 2013
    Be sure to try all of the switches on your dash and one of them may be the smoke screen so the DOT can't find you.
  8. Oi!
    Oi! Road Train Member
    1,233
    935
    Jun 20, 2011
    Florida
    Alcohol and tobacco compartment
    Peterbilt_Rick and chalupa Thank this.
  9. snowwy
    snowwy Road Train Member
    20,525
    13,261
    Jul 6, 2009
    the switch is for you to turn it off. i don't know under what circumstances you'd turn it off for though.
    i wish my truck at ATC.
  10. thedrifter
    thedrifter Medium Load Member
    522
    263
    May 23, 2010
    portland or.
    In my KW the switch was a momentary type. That when flipped would go back to its original position but the dash light would blink telling me that the atc was on. If you ouch it up again it would turn the light off. The atc would work I presumed even if I didn't activate the switch. Because when I woul lose traction or the truck procieved I lost it the light would come on for a second. I know that at. Works. It is nice to have.
