What is overdrive on a truck?
Discussion in 'Peterbilt Forum' started by ralin10, Feb 27, 2016.
  1. ralin10
    ralin10 Bobtail Member
    41
    4
    Apr 24, 2014
    hello everyone! Just curios about it, there are trucks with overdrive and without. Can you guys explain how overdrive works on a truck, you know on regular cars overdrive is activated with a button or switch. What about on trucks?
  3. Movingismylifeilovemoving
    Movingismylifeilovemoving Light Load Member
    230
    292
    Aug 5, 2015
    Someone will be around shortly with the detailed answer. In the mean time here is my limted information regarding something i know nothing about:)
    If you start in first gear the tires are odviously doing less revolutions than the (flywheel?) Overdrive would be the point where the gear ratio gets to a point that the wheels (through gearing) rotate faster.
    Think about a ten speed bike. In the highest gear your legs are going faster than the wheels. Overdeive would be the point the gears allowed tour legs to spin less the the revs of the wheels.
    I think thats it...
  4. oicu812
    oicu812 Medium Load Member
    637
    714
    Sep 24, 2010
    Wisconsin
    Direct drive means that the output shaft from the engine is turning at the same speed as the drive line at the back of the transmission. In overdrive, the output shaft from the engine to the transmission will be turning slower.
  5. Movingismylifeilovemoving
    230
    292
    Aug 5, 2015
  6. blairandgretchen
    13,216
    70,220
    Dec 9, 2011
    South west Missouri
    Direct drive is 1:1
    Overdrive is anything less than 1:1, like 0.87:1
    Basically - if it's a direct drive 10 speed, then tenth gear is direct.
    If it's a 10 speed OD, which most are, then 9th gear is direct, and 10th is OD.
    The engine turns less RPM in OD gears, to achieve the same wheel rotation.
    jammer910Z Thanks this.
  7. Movingismylifeilovemoving
    230
    292
    Aug 5, 2015
    But isnt the most of efficiency achieved at direct drive?
  8. tucker
    tucker Road Train Member
    12,647
    40,422
    Jun 13, 2008
    IN
    Overdrive in cars and pickups is just the highest gear.
    Chevy had 3 speed automatic transmissions forever, then went to the pos 700 "overdrive" transmission, which was basically a 4 speed.
    Nowadays I'm sure they all have 6 speeds? Who knows? Nowadays if the windshield gets dirty, people buy a new vehicle.
    But,what is this overdrive you think is in the big trucks?
    We have 9, 10, 13, and 18, (plus more or less) geared transmissions.
    I think you're confused, and most the answers you got before me, are complete nonsense.
  9. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,482
    Oct 18, 2009
    Waynesburg, Pa
    Umm.... I'm thinking you are the confused one. Yes the 700R4 was an overdrive trans yes it was a 4 speed and 4th was overdrive. But.....
    Overdrive has nothing to do with being the last gear in the trans... although most of the time it is. It's called that because the tail shaft or drive shaft is being over driven meaning it is turning faster than the engine. One gear is direct drive everything below is under driven everything higher is overdrive.
    Yes direct is more efficient than over drive but only by a few percent (because of the added heat). But in the real world you are not likely to see it. It's better to be in the engines sweet spot OD helps you get there.
  10. beemergary
    beemergary Light Load Member
    229
    112
    Apr 11, 2014
    Transmissions for years were a 1-1 ratio in high gear. Anything less than the engine speed of the transmission tail shaft is an over drive. Overdrive will only get you better fuel mileage if your engine has the power (sweet spot) to run at that rpm.
  11. AModelCat
    154,281
    Depends on your transmission. Like was stated above if you've got an overdrive transmission the top gear will be overdrive. On 13 and 18 speed overdrive transmissions I believe the top 2 are overdrive (8th hole in high range will be overdrive but you can split that gear so you'll have 2 overdrive gears.
