What is it with KW?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by johnday, Aug 7, 2011.
  1. johnday
    johnday Road Train Member
    They stop like garbage when bobtailing, and heavy loads. I had a T6, brand new, a T8, and drove my 2nd T8 a few days ago. Everyone of these trucks stopped terribly bobtailing, and the last T8 with 130k gross felt like it didn't want to stop then either. I normally drive a 4900SA Star Car, it stops good with or without a load, and bobtailing. I've bobtailed Centuries and Volvo's, and IHC's, all were better than any of the KW's.
    I'm normally at 120k plus, 7-8 axle chip boxes. So it's not like the KW had any more load than my Star Car.
    I don't care to set foot in another KW at this pointe.:biggrin_25513:
  3. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,482
    Oct 18, 2009
    Waynesburg, Pa
    I am going to guess the ones that have poor brakes bobtailing are older Kws. They would restrick the air going to the drives to keep from locking them up as easily. The cure for that was to place a quater between the glad hands and push the red knob in. My 06 Kw is not that way. It brakes fine with or with out a trailer. As far as being loaded dont have a answer there maybe the way the truck is speced? Mine stops fine with 112000 on five axles.
  4. Displaced Yooper
    Displaced Yooper Light Load Member
    152
    49
    Oct 18, 2010
    Detroit, MI
    Dunno what to say about the poor stopping... I used to own a '96 W900 & had zero braking issues while bobtailing, and the same is true of my '06 T2000.
    Poorly maintained? Restriction device as DL550CAT mentioned? Hard to say, but by far, not all KW's exhibit that behavior.
  5. johnday
    The T6 was an '07, and both T8's were/are 06's. Both T8's were 18k front, 46k rears, 4:10/4:11. The T6 was a typical road tractor, nothing really heavy duty about it.
    Now I'm totally ignorant here, I thought the brakes were standard regardless of the specs.
    The one T8 I've pulled the same chip box as the Star Car with no issues.
    Both the T8 and the Star Car have the same specs.The guy that normally drives the KW said he hadn't noticed what I'm talking about, but I think he's just used to it, it's the only truck he's driven for a few years.
  6. Prairie Boy
    Prairie Boy Road Train Member
    3,258
    1,913
    Nov 18, 2010
    Edmonton, AB
    It's equipped with a Bobtail Control Valve Control. If you don't know where it is, get a mechanic or someone at KW disconnect it for you. They've been around for quite a while, had one on a '95 W900L.
  7. johnday
    I don't think any of the trucks had poor maintenance, especially the T6 and the T8 I just drove. The restriction device is a possibility. Hopefully tomorrow I'll get a chance to talk with one of our mechs. It just didn't instill a lot of confidence in the brakes. It had been a few years since I'd been in a KW.
  8. johnday
    Would that affect stopping even with a trailer?
  9. Prairie Boy
    3,258
    1,913
    Nov 18, 2010
    Edmonton, AB
  10. johnday
