What is included in a Cummins in-frame rebuild
Discussion in 'Experienced Truckers' Advice' started by Gurjap, Jan 3, 2021.
  1. Gurjap
    Gurjap Light Load Member
    57
    11
    Mar 18, 2020
    Hello friends,
    I own a 2010 kenworth T800 Cummins isx, which is due for an in-frame rebuild. However my turbo, water pump and injectors are working completely fine. Do I need to get these changed too if I’m doing the rebuild or can I use existing parts?
    Also what is included in a Cummins isx engine rebuild?
    Any input will be greatly appreciated.
    thank you.
    bzinger Thanks this.
  3. bzinger
    bzinger Road Train Member
    16,593
    65,733
    Dec 10, 2014
    omaha , ne
    I re used my turbo , water pump and injectors on my 2013 isx when over hauled at 684 ...everything else went in the scrap pile .
    897k on it now with no issues.
    Gurjap, D.Tibbitt and JonJon78 Thank this.
  4. Farmtractor9900
    Farmtractor9900 Light Load Member
    162
    433
    Nov 6, 2020
    Classic The Classic Kit contains the basic to keep you on track: Rings, Liners, Bearings, Gaskets, Filters, Thermostat, Locknuts, and Oil Bypass Valve
    Pro The Pro Kit Contains the Classic Kit Plus ReCon Cylinder Head, Pumps, Roller Tappet and Plunger
    Elite The Elite Kit contains the Pro Kit contents PLUS Fuel Connectors, and ReCon Fuel Injectors and Connecting Rods
    Genuine ISX Overhauls
    New ISX Overhaul Kits are the latest and greatest offering for EPA 2010 (CM2250) and EPA 2013 (CM2350) engines. ISX Overhaul Kits are tiered to provide the level of parts and repair that best match your budget and engine needs. CLASSIC, PRO, and ELITE kits are priced to save you more than buying parts individually, cutting down costs to keep you on the road. To learn more, watch our video.
    CLASSIC Kit – Basics to Keep You On Track: • Pistons and Rings • Cylinder Liners • Main Bearings • Upper Engine Gasket Set • Piston Cooling Nozzles • Connecting Rod Bearings • Oil Pan Gasket • Fuel and Lube Filters • Oil Bypass Valve • Coolant Thermostat • Turbo Studs/Locknuts
    PRO Kit – Essentials to Extend Your Horizons: • Classic Kit Contents + • ReCon® Cylinder Head • ReCon® Lube Oil Pump • ReCon® Water Pump • ReCon® Fuel Pump (Short Block)* • Fuel Pump Roller Tappet* • Fuel Pump Barrel and Plunger* - *Contents are not included in ISX 12L Overhaul Kits
    ELITE Kit – Everything You Need for The Long Road Ahead: • PRO Kit Contents + • Fuel Connectors • ReCon® Fuel Injectors • ReCon® Connecting Rods
    Reason for edit: TMI
    mitmaks, Gurjap, JonJon78 and 2 others Thank this.
  5. slow pok
    slow pok Light Load Member
    144
    211
    Oct 27, 2013
    lizela ga
    That’s a long commercial
  6. Farmtractor9900
    162
    433
    Nov 6, 2020
    10-4. I thought I only copied the classic-pro-elite kit part.
  7. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    What’s the cost of all this.......?
    RunningAces Thanks this.
  8. Farmtractor9900
    162
    433
    Nov 6, 2020
    I bought the pro kit 4 years ago and I think it was 8700
  9. AKDoug
    AKDoug Medium Load Member
    323
    801
    Mar 21, 2018
    You won't know which one you will need until it comes apart.
    haycarter and AModelCat Thank this.
  10. RunningAces
    RunningAces Road Train Member
    1,263
    2,513
    Jul 2, 2017
    How much to have an inflame of an isx15 2350 done?
  11. AKDoug
    323
    801
    Mar 21, 2018
    Once again, it all depends how much work is going to be done and what needs to be replaced. Budget for $25K and thank your lucky stars if it comes in less.
