What is in a fuel tank?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Bdog, Aug 1, 2015.
  1. Bdog
    Bdog Road Train Member
    1,057
    877
    Nov 6, 2014
    I have a 98 Kenworth W900. The fuel gauge has never worked since I owned it. A few days ago I started hearing a rattling noise and the truck randomly sputters from time to time. I have narrowed down the noise to something inside the fuel tank and I am guessing the sputtering has to do with the fuel tank as it seems to happen along with bumps on the road.
    I am guessing there is a float assembly for the gauge and maybe it fell apart inside the tank and is now blocking the tank drain going to the injector pump.
    I see a fitting and hose at the bottom of the tank. Is it just a simple drain or is there some type of screen or something inside the tank?
  3. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,588
    Dec 29, 2014
    Orrstown, PA
    Grab a bright flashlight and look in the filler neck. The high power LED ones work good to see what's inside there, even with allot of fuel.
  4. scottied67
    scottied67 Road Train Member
    10,816
    12,615
    Mar 14, 2010
    california norte
    Could be the antisiphon cans fell in, mine did.
  5. FLATBED
    FLATBED Road Train Member
    Do not drop the FLASHLIGHT into the tank like I saw a driver do 1 night at a truck stop :)
  6. Stubby T Slapnutt
    Stubby T Slapnutt Light Load Member
    169
    134
    Jul 20, 2012
    the tank is most likely aluminum, the parts for fuel gauge most likely will not be made of aluminum, get a magnet on a stick or on a string, go fishing.
  7. Caterpillar Cowboy
    Caterpillar Cowboy Heavy Load Member
    837
    607
    Nov 11, 2010
    Wyoming
    I've only had the gauge sending unit out and apart on a Pete, it was a plastic float setup, and depending on if you're a top draw or bottom draw I guess it could be an issue for blocking the pickup?
    You'd have to be on some pretty darn smooth roads though to keep form jostling that stuff around, I don't think that that is your issue.
    May be handy if you had one of those little lighted inspection lights and cameras with a 2 foot or so whip to get in there and see what's going on.
  8. OldHasBeen
    OldHasBeen Road Train Member
    1,269
    924
    Dec 16, 2010
    A friend of mine driving a dump truck was not sure how much fuel he had. He had pulled into his brothers service station on Main Street. So he pulled his cigarettes lighter out of his pocket held it close to the fuel cap opening while bending down to look into his fuel tank to see how much fuel he had.
    A great big flash came out of his fuel tank, and it burnt his face, his brother had to take him to the hospital.
    Thankfully it did not hurt his eyes permanently, but it did leave some scars on his face. He learned a very good lesson that evening and I don't believe he ever did that again.
    Talking about looking down in a fuel tank reminded of this, some people do some real stupid things.
    OLDSKOOLERnWV Thanks this.
  9. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    could be one of the baffles broke loose. like on mine. it clangs when I stop.
  10. Bdog
    1,057
    877
    Nov 6, 2014
    Thanks for the replies guys. I will get a light and a magnet and see what I can find. Whatever it is this cutting out started at the same time the noise did.
