What is an “In Frame”?
Discussion in 'Ask An Owner Operator' started by Midnightrider909, Oct 9, 2018.
  1. Midnightrider909
    Midnightrider909 Road Train Member
    2,383
    9,599
    Oct 26, 2016
    I hear this term thrown around a lot and I am guessing it has something to do with rebuilding the engine but what does it matter if it’s in the framer out of the frame?
  3. HopeOverMope
    HopeOverMope Road Train Member
    1,801
    3,210
    Feb 25, 2016
    I-20 LOUISIANA
    Inframe is a bit cheaper than an out of frame. The terms suggestjust the meaning. In frame is a motor rebuilt within the frame ( still attached ). An out of frame is when a motor is literally pulled out of the frame and rebuilt outside the truck. There’s a bit more labor involved in a out of frame rebuild, but it gives u the opportunity to put in new motor mounts and etc.
    A basic rebuild is, liners, pistons, main n rod bearings. Everything else is optional or per circumstance / investment.
    bewhite90, Lepton1, 77fib77 and 4 others Thank this.
  4. Midnightrider909
    2,383
    9,599
    Oct 26, 2016
    Wouldn’t the piston liners also need replacing and the crankshaft have wear? How about the heads, camshafts, valves, pulleys, seals, etc? I would think it would be a lot faster just getting a remanufactured engine and swap them out and use your old one for a core.
  5. HopeOverMope
    1,801
    3,210
    Feb 25, 2016
    I-20 LOUISIANA
    Some people do this. Replace with a crate. But in a rebuild, The crankshaft is inspected for wear. Crankshafts tend to last two motor rebuilds. Sometimes more, sometimes less. A BASIC rebuild is liners, pistons, and bearings. Anything and everything else is user discretion
  6. Dino soar
    Dino soar Road Train Member
    4,789
    26,858
    Dec 8, 2017
    An in frame is when you have an engine that has good oil pressure and you've always change the oil in it Etc, but now you are burning oil but the engine itself is still in good shape.
    So new rod and main bearings are put in new pistons and liners and rings and if you like you can have new heads or have your heads gone over.
    Out of frame means that the entire engine comes out of the frame and everything on the engine is disassembled. All of the journals are checked the camshaft all of the bores everything in the whole engine is check the block is sent out and magnafluxed and most likely you will have a new crankshaft or cut crankshaft and a new camshaft, etc. This is a major overhaul and you will probably put all new parts all over the whole rest of the engine.
    The idea is that if you have a diesel engine that has some miles on it that the oil and filters have been changed properly and has not overheated, an in frame will renew the engine for many many miles to come without having to pull the entire engine out and do the whole thing. At that point the out of frame rebuild is not necessary saving you time and money.
    If an out of frame rebuild is needed it probably is a good idea to buy a crate motor just due to the time and expense and labor involved.
    Depending on the engine an in frame can be relatively inexpensive.
  7. 201
    201 Road Train Member
    12,042
    24,575
    Apr 16, 2014
    high plains colorado
    In frame=:biggrin_2556:
    out of frame=:biggrin_25521:
    Lepton1, Cattleman84, 77fib77 and 4 others Thank this.
  8. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,541
    May 22, 2017
    In frame= 1 arm.
    Out of frame= 1 arm and, 1 leg.
  9. Ridgeline
    22,098
    113,135
    Really midnight?
    Oh well .. inframe as they said is an overhaul with the engine in the truck. Other than decking the block and putting in "fire rings", I've seen inframes being a complete overhaul, including cam bearings and new cam.
    Lepton1 Thanks this.
  10. Midnightrider909
    2,383
    9,599
    Oct 26, 2016
    Decking the block and putting in fire rings makes me think I need to get my muffler bearings and turn signal fluid doser checked as well.
    Lepton1 and 86scotty Thank this.
  11. 77fib77
    77fib77 Road Train Member
    10,162
    62,703
    Jul 7, 2010
    St Louis
    Decking is when you put a new head on and you make sure the top of the block is perfectly flat for the new head. Pretty sure that what it is. Someone sitting at a shipper will add too it.
    Midnightrider909 Thanks this.
