What is a truck's MPG and fuel capacity?
Discussion in 'Questions From New Drivers' started by hopeful eyes, Dec 15, 2020.
  1. hopeful eyes
    hopeful eyes Medium Load Member
    482
    336
    Jul 4, 2020
    Richmond, Virginia
    How much thirst they have for diesel, and how many gallons of diesel are in the tank?
  3. hopeful eyes
    482
    336
    Jul 4, 2020
    Richmond, Virginia
    Also, can you use your personal credit card to buy Diesel for the company truck to get rewards lol?
  4. meechyaboy
    meechyaboy Heavy Load Member
    794
    1,226
    Oct 4, 2018
    Detroit, Michigan
    My local day can has a 100 gallon tank on it and I get about 3.3 mpg loaded but I pull over 80k
    When I was Otr i had 2 100 hundred gallon fuel tanks and that truck was a fuel efficient new freightliner.. I was getting about 9mpg. But I didn’t shut my truck off for months..
    You don’t want to use your personal card to buy diesel, the company will give you a fuel card to purchase diesel and def and each store has its own rewards card like loves and pilot. It’s kinda like a speedy rewards card. It holds your showers and gets your tons of free stuff if you save up you could get some nice stuff.. I bought my 110$ cb with points and when I came home I still had about 160$ in rewards.
  5. Brandt
    Brandt Road Train Member
    4,409
    5,945
    Sep 17, 2012
    You can spec a truck with 1 tank that holds 75 gallons or 2 tank upto 150 each tank. Most trucks have 2 tanks that hold 120 gallons each.
    You would never use your personal credit card to buy fuel for a company truck. They give you a credit card basically. Lots of companies use Comdata, is a card truck stops take and you fill the truck up when you need fuel. You get the driver rewards card from the truck stop. When you buy fuel you swipe your Comdata fuel card, then you driver rewards card. That way you get free shower credits and the rewards for buying the fuel.
    Rideandrepair and hopeful eyes Thank this.
  6. Brandt
    4,409
    5,945
    Sep 17, 2012
    A new truck today can get 7.8 or 8 MPG pretty easy with APU. If they build/spec a truck for MPG, not everyone does that so might only get 6.5 MPG or something. Back in the 90s caterpillar engines might only get 5 MPG
  7. Blue Zombie Trucker
    Blue Zombie Trucker Light Load Member
    279
    681
    Nov 1, 2017
    Make sure you use the truck stop chain's rewards card. Pilot/Flying J has a gig where I'm usually getting 4X reards points for the last half of the month. I've bought a CB, a mic, an decent antenna and mount, tons of soft drinks... and I spent no moneys.
    My '18 FL New Cascadia, 500hp 15L w/ manual 9 speed has 190 gal capacity, mpg varies a LOT with payload weight, weather, terrain, WIND, anything from 3-4 on hard long climbs to nearly 10 deadheading. Avg around 7.8mpg.
  8. austinmike
    86,242
    My Freightliner with a Detroit 60 gets about 5.5 miles per gallon. Always close to 80k pounds. Fuel gage quit working aboot a year ago so I go by the gallon meter. With two 80 gallon tanks I fill it up at around the 100 gallon mark.
  9. hopeful eyes
    482
    336
    Jul 4, 2020
    Richmond, Virginia
    Man trucks are such thirsty beasts lol. They have horrible gas mileage.
    Rideandrepair Thanks this.
  10. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,483
    Nov 11, 2008
    Sorrento Maine
    Depends on the truck, how heavy the drivers foot is, as well as the size of the fuel tanks.
    Company trucks will usually have 150-200 gallons max.
    The Cascadia trucks can see almost 10 mpg. @Dave_in_AZ has had his truck up to 9.4 mpg (blackie, name of the truck)
    If you can drive conserveatively around 65 you will do betteer than a driver whom mashes the pedal to the floor and does 85.
    The tired Columbia I drove for Western Express with a plugged air filter (they didnt want to change it) got almost 5.8 mpg. It was governed to 62mph
  11. AModelCat
    154,360
    Anywhere from about 3 to 10 mpg. A lot of variables at play. Van trailer, light loads, flat ground and aero truck will be closer to 10. Heavy loads/oversize loads, mountains/hills, high horsepower is going to be on the lower end of the spectrum.
