What is a partner carrier relationship????????
Discussion in 'Ask An Owner Operator' started by rookietrucking88, Aug 4, 2021.
  1. rookietrucking88
    rookietrucking88 Bobtail Member
    4
    First off, I apologize if I'm posting this in an incorrect forum--as you will see, I'm not the most knowledgeable on "all things trucking." I would appreciate if anybody would be able to provide me clarity onto what a partner carrier relationship entails? From what I've read so far, an O/O--also a power only driver if I'm not mistaken--essentially works with or for a larger carrier to transport a shipment using another carrier/shippers trailer. With this partner carrier relationship, are O/Os literally leasing their vehicles and services to the larger carrier? Or are O/Os receiving a percentage of the haul? Or maybe both? Do these vary from relationship to relationship? Are O/Os allowed to do independent work and/or work with other carriers while being signed on with a certain carrier?
    Basically to sum it all up, what does a typical partner carrier relationship look like--insurance/financially, liability, etc.
    Any help is appreciated! Thank you!
  3. mudflap77
    mudflap77 Heavy Load Member
    863
    1,313
    Oct 11, 2010
    South western Ontario
    A partner carrier is just another carrier that they can use to cover overflow loads, loads going to an area not serviced by the customers primary carrier or loads requiring equipment the primary carrier doesn't have. Could be a one truck show or a larger carrier.
    rookietrucking88 Thanks this.
  4. rookietrucking88
    4
    Thanks! So if I sign on to be a partner carrier with another company, would I be strictly working for that sole company or could I venture out and work on my own/work with other carriers? Also, would I be compensated by leasing my truck/services or through a percentage of the haul? Or does each partner carrier relationship differ in terms of forms of payment?
  5. Ridgeline
    22,101
    113,190
    Most of the agreements I have are verbal, the written ones a have no exclusivity clauses.
  6. mudflap77
    863
    1,313
    Oct 11, 2010
    No as a carrier you are not stuck to one company. If you lease on to that company then you would work solely for that company
  7. ProfessionalNoticer
    2,941
    7,852
    Apr 25, 2021
    These are questions you should be asking the Carrier directly.
  8. rookietrucking88
    4
    Do you mind sharing the way in which you are compensated (i.e., by leasing your truck/services, by a set rate for the haul, or through any other way)?
