2013 FREIGHTLINER, CASCADIA 113, Heavy Duty Trucks - Conventional Trucks w/ Sleeper, Detroit DD13, 10 Spd, Nice Clean Truck! Select Inspected and Certified! Serviced, DOt'd, Cleaned and Detailed! New Premium Innerspring Mattress! Great Lightweight Specs! Lots of Options! Excellent Matched Goodyear Virgin Rubber on the Rear! Select Warranty Available! Great Financing Thru Daimler Truck Finance! Call Today! : This is a 6 X 2 Drivetrain.Note, 450 Horse Power, Suspension, Aluminum Wheels, 220 Wheel Base, LP22.5 F, Wide Base R, Tandem Axle, Ratio, 72 Raised Roof Sleeper,
would this truck be ok for general OTR use?
What is a 6x2 drivetrain?
Discussion in 'Freightliner Forum' started by Opus, Apr 22, 2018.
Page 1 of 3
Means only first drive axle is powered. Rear drive axle is just along for carrying the weight. No driveshaft between the pumpkins. Saves on weight, probably a little better on fuel maybe a few %, but sacrifices the ability for 3 or 4 way lockers. If running where traction is almost never an issue it should be fine. I would never run it, but I do a lot of winter driving and the 4 way lockers are a must (in my mind).
Some people will argue otherwise. I don't buy it. -
If you buy a 6x2, check to see if the 2nd axle differential is convertible, meaning that a driveshaft can be added later incase a owner decides to replace the 3rd trailing axle with a differential and turn the truck into a 6x4.
It'll help with resale value later as 6x4 are more desirable and common. -
Mail hauler had quite a few 6x2 some years ago and those trucks were constantly spun out on grades on Hwy 17 along Superior. It was quite pathetic.
AModelCat Thanks this. -
Should be ok if he just hangs out down there all the time.
Even with all that, one time the truck needs a hook and there goes all the fuel savings.. I'm sure there's videos where a truck is stuck on an odd section of pavement if it can only spin the 1 wheel..Bean Jr. Thanks this. -
Most of these 6×2's also at least have a locker on the front which helps a lot in sticky situations. The weight savings is substantial over the life of the truck, plus less maintenance, parts to break, and wear out. Definitely a no go In the north, I agree.
Normally they're unlocked and just spins right side
Engage locked and it will spin both
So when you make turns one side needs to turn at a different speed than the other. That's why it's like that. -
Page 1 of 3
